Cams?? - Mustang Evolution
Old 06-14-2011, 05:46 PM   #1
stangstar92's Avatar
Cams??
I was wondering if I could put a 3/4 inch lift on my motor. Has anyone done this, would it work out for my motor. My motor has been fully been rebuilt. Forge pistons, rods, and crank. It's at a 9-5 to 1 compression ratio...
2002 Gt Mustang - Built 2 Valve
"Real cars don't power the front wheels...they lift them"
stangstar92 is offline   Reply With Quote
Old 06-14-2011, 07:42 PM   #2
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: Cams??
I don't think you're asking the right question....
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-14-2011, 08:02 PM   #3
Idk, I was just wondering if I can put a 3/4 inch lift cam in my car
Old 06-14-2011, 08:17 PM   #4
Re: Cams??
So you want to put a .750 lift cam in your car? Is that what you're saying?
-Will
Waffles
Old 06-14-2011, 08:22 PM   #5
Yea
Old 06-14-2011, 08:33 PM   #6
Re: Cams??
You need to do a LOT more research.......
.750 lift is ridiculous. Your car has no need for cams like that...and I'm fairly certain nobody makes a 2V cam with anywhere NEAR that much lift.
You know all of those outrageous LS1's you hear with the massive cams? They're usually less than .650 lift......and they're an OHV car, not an OHC.
"Aggressive" cams for your car would be somewhere in the upper .5xx range...
-Will
Waffles
Old 06-14-2011, 10:41 PM   #7
Alright thx, someone was telling me I could, that's why I was wondering. I didn't know if it was possible.
Old 06-15-2011, 10:36 AM   #8
stampde's Avatar
Re: Cams??
with a 4.6 a .580 lift cam with 275 duration , is pretty stout for the street
2011 GT Auto
Old 06-15-2011, 04:27 PM   #9
Re: Cams??
I think im going to get comp cams XE278AH
Old 06-15-2011, 09:40 PM   #10
Re: Cams??
My advice would be to call up Comp and tell them what you have and what you want to do. They can tell you the right cam for the job
-Will
Waffles
Old 06-17-2011, 10:17 AM   #11
So would XE278AH cam be fine for let's say a factory motor. Mines not factory, but the duration being 278 it would work with a tune, gears and exhaust...or is more that needs to be done to the motor and so forth?
Old 06-17-2011, 11:38 AM   #12
1bad01gt's Avatar
I have the stage 2 cams that comp makes. Have had them for several yrs now stock internals and 8psi blower and have had no issues. Think with the stage 3 cams you have to change the valve springs? Sounds good to.
1bad01gt is offline   Reply With Quote
Old 06-17-2011, 11:43 AM   #13
Alright thanks, I was gonna change the springs anyway
Old 06-17-2011, 11:05 PM   #14
Re: Cams??
If you want an answer from guys who spend all day specking cams, call the Comp Cams Techline.
-Will
Waffles
Pi cams ?'s 1995procharged 1996-2004 Mustang GT 1 09-07-2009 12:16 AM
new cams COmustang 1996-2004 Mustang GT 3 05-12-2008 02:03 PM
Cams ridenmystang 1996-2004 Mustang GT 10 12-12-2006 07:12 AM
Cams megax29 Pre-2005 V6 Mustang 11 04-01-2006 01:07 PM
anyone have any cams out there? Zim Mustang Parts for Sale and Wanted 5 03-05-2005 06:59 AM
12:49 PM
