Front End Issues - Mustang Evolution
Old 06-14-2011, 06:34 PM   #1
StangSims39's Avatar
Front End Issues
Hey everyone,
So i noticed this after my header install so we will keep that in mind n hope to figure out what the deal is. When i step on the gas from a stop i feel a rubbing and what sounds like a thumping like something is hitting the top n bottom of something coming from the front end. I feel it also when turning and hitting the gas going left or right. When i do a power break to test to see if its the headers hitting the steering rack, but the mounts are solid and no clunk when doing a power break. This is really starting to annoy me, what could this be?
StangSims39 is offline   Reply With Quote
Old 06-14-2011, 10:48 PM   #2
junoS197Bl08's Avatar
Re: Front End Issues
I would check the bolts on your headers and make sure they r tight, if they are loose at all that could be the source. Other then that I don't know what to tell you right now.
2008 V6 Windveil Blue with 5spd standard transmission-pony package, replica rims, shorty antenna
junoS197Bl08 is offline   Reply With Quote
Old 06-15-2011, 08:09 AM   #3
yea and look for rubbing spots where something is hitting
Old 06-15-2011, 09:01 AM   #4
done and done, the header bolts are tight, they were retorqued twice, most recent as this past saturday, they are tight, and there is plenty of clearence between the header and the steering column. My first thought was it was the header hitting the steering and that my mounts were loose or shot, but by doing a power break and torquing the motor im not hearing any bang or clank, which to me rules out that its the headers hitting anything. im thinking something is just loose in the suspension, but i cant put my finger on it.
Old 06-15-2011, 09:03 AM   #5
Send a message via Skype™ to Texastboneking
Just an idea... You could check the swaybar bushings. They might be shot
Texastboneking is offline   Reply With Quote
Old 06-15-2011, 10:16 AM   #6
That is where I was going next I'm gonna be I stalling my smoked fogs today so when I'm under there I'm gonna check them out I'm hoping it's something simple and easy as that
Old 06-15-2011, 10:23 AM   #7
wereKEV's Avatar
Y ou don't have a bad motor mount do you?
wereKEV is offline   Reply With Quote
Old 06-15-2011, 11:28 AM   #8
no, the motor mounts are good, those were checked first, its solid when powerbreaking and taping the gas to torque the motor, its only on launch.
Old 06-15-2011, 11:31 AM   #9
wereKEV's Avatar
Sounds like another case of AUTOMOTIVE UNSOLVED MYSTERIES.
Old 06-15-2011, 12:05 PM   #10
hahaha i know, im cutting out of work @ 4 gonna go to my mechanic and have him take a drive so he hears it, and go from there, hopefully its just somethign that needs a lil re-torquing. Im just puzzled.
Old 06-15-2011, 04:34 PM   #11
He can't hear or feel what I do very frustrated
Old 06-16-2011, 12:20 PM   #12
wereKEV's Avatar
Thats always what happens when you try to have someone hear or feel something your car is doing it don't do it , then when you are on your way home it happens again.
Old 06-16-2011, 12:34 PM   #13
Yup it did it a lil bit but he most likely could not hear it over my exhaust then he took it for a spin himself n nada I make turn out of the lot and there it is gonna jack the car up after work today and check it out
Old 06-17-2011, 09:11 AM   #14
1bad01gt's Avatar
Did you go with long tubes? If so I had clearance problems on the passenger side, around the starter area.
1bad01gt is offline   Reply With Quote
Old 06-17-2011, 11:00 AM   #15
Equal length shorties bbk
Old 06-24-2011, 01:47 PM   #16
Ok so just got back from the shop the k-member was a lil loose tightened everything all Bushings are good looked at the header and it is hitting marks on the header and steering shaft so now why can be done to stop this lol
Old 06-28-2011, 05:05 PM   #17
I'm going to get polly mounts hopefully that will resolve the problem
Old 06-28-2011, 05:09 PM   #18
Can I have the solid mounts???
Old 06-28-2011, 06:22 PM   #19
Solid mounts are really for race applications only, its just solid steel
Old 06-28-2011, 06:42 PM   #20
I know what they are. I want them cause I've already shredded two sets of rubber mounts...
Old 06-28-2011, 07:27 PM   #21
So go polly from what I have read they are great and 10x better than rubber
Old 06-29-2011, 10:44 AM   #22
BayyGT's Avatar
The pollys will definitely help. When I first installed my bassani mid lengths I had very noticeable rub at start up and when accelerating. After a few weeks everything seemed to settle in to place and the vibrating reduced alot. When I pulled the motor I did notice a small spot on the k member where one of the headers were rubbing.
BayyGT is offline   Reply With Quote
Old 06-29-2011, 12:49 PM   #23
Ok cool yeah I noticed the rub n hit marks on the steering shaft n headers. Good to hear I'm hoping to order this week
Old 06-29-2011, 05:02 PM   #24
Or you could send me yours free
Old 06-29-2011, 08:10 PM   #25
What?? Have what free?? U ok man? Lol
Old 06-30-2011, 10:39 AM   #26
I'm fine . You? Free?
Old 06-30-2011, 11:32 AM   #27
wereKEV's Avatar
Nothing in this world is free.
Old 06-30-2011, 11:34 AM   #28
after reading the posts trying to figure out what the hell your talking about, it looks like you misread my posts. i dont have solid mounts, i said my mounts feel solid, meaning my stock rubber mounts, after looking at my headers and steering column that is not the case, hence why im going with the polly mounts. if i had solid mounts there would be absolutly no twist at all and my headers would never hit the steering column and woudl never need to downgrade to polly mounts. my car is a DD so the use of Solid mounts is not needed. Hence again why im going with the polly, just ordered them today, cant wait to ditch the crappy rubber mounts.
Old 06-30-2011, 11:35 AM   #29
This too lol
Old 06-30-2011, 12:00 PM   #30
Ooooo... I don't want them anymore lol
Old 06-30-2011, 12:00 PM   #31
Suntans are free...
Old 06-30-2011, 12:02 PM   #32
wereKEV's Avatar
no they are not free you had to buy the shoes or the gas to get to where you get the tan or ay least had to buy the bathing suit.
Old 06-30-2011, 12:26 PM   #33
I tan nude in the front yard.
Old 06-30-2011, 12:31 PM   #34
Pete07GT's Avatar
Send a message via ICQ to Pete07GT Send a message via AIM to Pete07GT Send a message via Yahoo to Pete07GT
No wonder why people refuse to drive past your place.
When you're going to war, you better have three things if you expect to win: 1. Willpower (One's need to put the petal to the metal); 2. Staying Power (300+ BHP); and 3. Firepower (The wheels of your mustang exploding on the highway like a slug from a .45).
Pete07GT is offline   Reply With Quote
Old 06-30-2011, 12:33 PM   #35
Lol I have no neighbors. I live out in the middle of nowhere...
Front end Noise ?????? ArmyStangGT 1996-2004 Mustang GT 7 02-09-2009 09:13 AM
98 GT front end meteorachick Mustang Parts for Sale and Wanted 6 07-28-2008 06:53 PM
Destroyed the front end! :( fasternu_674 Mustang Audio & Video 27 03-31-2008 03:04 PM
Saleen Front End Black95GT Mustang Parts for Sale and Wanted 11 10-14-2004 12:32 PM
saleen front end?? v6white98 Mustang Audio & Video 10 12-22-2003 01:32 PM
06:22 PM
