only one wheel spinning on my 1996 mustang gt - Mustang Evolution
Old 06-15-2011, 01:36 PM   #1
vinnygt's Avatar
is it the trac lok that isnt working? how can i fix this? how much will it cost?
vinnygt is offline   Reply With Quote
Old 06-15-2011, 02:38 PM   #2
mrc
mrc's Avatar
Re: only one wheel spinning on my 1996 mustang gt
Sounds like you need to have your tlok rebuilt. You can buy a kit from Ford or Americanmuscle.com. You will probably need to have a shop do the rebuild. From what I've heard they aren"t something you can usually do with out heavy mechanic experience.
PI intake manifold swap,Stack racing CAI, Lawson Incinerator mufflers, SCT tuner.
mrc is offline   Reply With Quote
Old 06-15-2011, 02:42 PM   #3
sounds like the clutches are going out and the Tlok needs to be rebuilt. its not a huge deal to do, not sure on price of the clutches but probably 200-300 for labor~ or should be at least.
Old 06-15-2011, 03:05 PM   #4
vinnygt's Avatar
i see. thanks for the info. what would i need to do if i want to replace my 3:73 gears with something like 4:10 ? would i just need to swap them or do i have to change other parts?
Old 06-15-2011, 03:12 PM   #5
mrc
mrc's Avatar
Just buy an install kit when you buy the tlok rebuild kit.
Old 06-15-2011, 03:26 PM   #6
tlok replacment or removal/replacment of clutches and a gear change requires basically the same amount of effort. The extra effort is in shimming and setting the rear end fully (removal of drive shaft and pinion gear) etc so its not THAT much more work~ you should be able to save some on labor if you do both at the same time.
Old 06-15-2011, 03:28 PM   #7
mrc
mrc's Avatar
+1 to what Spector said. If your gonna open the rearend up might as well do both.
Old 06-15-2011, 03:59 PM   #8
vinnygt's Avatar
thanks guys. helped a lot
Old 06-15-2011, 04:16 PM   #9
vinnygt's Avatar
im new on this. it might sound kinda dumb but i cant figure out how to start a new thread or question. help please
Old 06-15-2011, 09:58 PM   #10
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
First thing to do is check the fluid lol
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
1996 mustang
1996 mustang? mustangmadnes09 General Car Discussion 6 09-04-2008 12:31 PM
1996 Mustang GT- Exhaust help koch_A_tyler 1996-2004 Mustang GT 12 06-12-2008 11:44 PM
i want a 1996 Cobra mustang!! Rollin Thunder The Bar 3 04-08-2008 08:05 AM
1996 Mustang HELP! roadfeet Pre-2005 V6 Mustang 2 04-23-2006 07:16 PM
1996 Mustang GT Buzz 1996-2004 Mustang GT 1 04-22-2006 01:48 PM
10:35 PM
