Stalling out randomly? - Mustang Evolution
Old 06-16-2011, 09:19 AM   #1
jbanks's Avatar
My GT has been randomly stalling out when I sit at a stop light or stop sign. It doesn't die every time but the rpms will drop from 750 to less than 500. Not a constant thing but has been happening fairly often. Any idea what this could be caused from?
Boom!
jbanks is offline   Reply With Quote
Old 06-16-2011, 09:23 AM   #2
Send a message via Skype™ to Texastboneking
Ac on or off?
Texastboneking is offline   Reply With Quote
Old 06-16-2011, 09:26 AM   #3
Re: Stalling out randomly?
could be the idle air control (IAC) or also known as idle bypass valve. They tend to go bad and they control the idle of the car.
It might also be (or in combination with) the mass air meter so clean the sensor.
and as said above the AC can lower rpms when running
Old 06-16-2011, 09:34 AM   #4
Few other questions.
Manual or automatic tranny
Check engine light on or off??
Old 06-16-2011, 09:40 AM   #5
do you have an after-market mass air flow sensor?
02 GT ~ Sold
04 MACH 1 ~ Current
Twist is offline   Reply With Quote
Old 06-16-2011, 09:50 AM   #6
or is the current maf rotated differently than from the factory or in a different location (aftermarket intake etc)?
Old 06-16-2011, 09:53 AM   #7
Jamesgt08's Avatar
My car use to do that alot too. Just clean your IAC MAF throttle body. I changed my cam and crank sensors and the problem stopped.
Jamesgt08 is offline   Reply With Quote
Old 06-17-2011, 06:10 AM   #8
jbanks's Avatar
Ac on or off, either way it happens. No aftermarket intake or mass airflow sensor. I'll take the advice I've received from you all and update if there's a change. Thanks for all the help.
Boom!
Old 06-17-2011, 07:26 AM   #9
yea buy some ON contact non residue electronic cleaner, remove the MAF sensor (tamper proof torx bit I believe and you can get to yours if its not inside the air box). If you are not sure what the MAF sensor it let us know.
Be easy getting it out/in and spray it down with cleaner good. The next thing is the IAC little round thing on the throttle body or right around it. You can apparently clean it by taking it off hosing it down and draining the stuff out~ it might be easier to just replace it.
Old 06-17-2011, 12:05 PM   #10
jbanks's Avatar
I know what the MAF Sensor is but I'm not sure what the IAC is... there are a couple of different little round things around the throttle body. How can I tell which one is the right one?
Boom!
Old 06-17-2011, 12:09 PM   #11
Jamesgt08's Avatar
The IAC is on the plenum. It has a wire hooked up to it. Its in the front.
Old 06-17-2011, 12:09 PM   #12
Two bolts hold it on. It's usually right on the throttle body. It's a syliniod so it's pretty decent size. Around three inches long. Usually a small air hose running too it
Old 06-17-2011, 12:39 PM   #13
jbanks's Avatar
Great, thanks
Boom!
Old 06-18-2011, 08:35 AM   #14
jbanks's Avatar
Cleaned the MAF and IAC and my car is running like a BEAST! No more stalling out/rough idle... and I can feel a major difference in throttle response. This forum probably saved me $300 in "dignostic" and "labor" charges if I put it in the shop.
Boom!
Old 06-18-2011, 11:11 AM   #15
glad we could help!
Old 06-03-2015, 04:25 PM   #16
Good info
Originally Posted by Texastboneking View Post
glad we could help!
Thanks for this...my 05 does the same thing, and my mechanic didnt know where to start.
Redcat65 is offline   Reply With Quote
randomly messes up blackonblack Pre-2005 V6 Mustang 10 08-23-2010 12:16 PM
stalling 5.0 vil8er New Member Introductions & Greetings 0 02-16-2008 02:12 PM
Car Stalling megax29 Pre-2005 V6 Mustang 7 01-26-2007 09:46 AM
stalling 94 gt wmustanggt 1979-1995 Mustang GT 8 07-02-2006 01:13 PM
stalling on startup Deadmeat101 Pre-2005 V6 Mustang 4 09-16-2003 07:00 PM
05:23 PM
