inaccurate speedometer on 1996 mustang gt - Mustang Evolution
Old 06-19-2011, 10:18 AM   #1
vinnygt's Avatar
my speedometer is about 15 mph off when im going at about 60. it says im going way faster. i dont know how it happened i got it like this but its getting kind of annoying lol. any ideas on how i can fix this?
vinnygt is offline   Reply With Quote
Old 06-19-2011, 10:25 AM   #2
Jamesgt08's Avatar
I seen u had 3.73s the gears make ur speedometer off like that. You need a tune.
Jamesgt08 is offline   Reply With Quote
Old 06-19-2011, 10:48 AM   #3
vinnygt's Avatar
Re: inaccurate speedometer on 1996 mustang gt
are you talking about a tune with a tuner or do u mean like a tune up at a shop.. srry it might be a dumb question but hey thats why im here to learn. lol.
Old 06-19-2011, 11:02 AM   #4
mrc
mrc's Avatar
They can fix it when you buy a tuner. They reconfigure your computer for the gears.
PI intake manifold swap,Stack racing CAI, Lawson Incinerator mufflers, SCT tuner.
mrc is offline   Reply With Quote
Old 06-19-2011, 01:53 PM   #5
vinnygt's Avatar
after i buy the tuner do i download the tunes from my computer?
Old 06-19-2011, 02:18 PM   #6
Jamesgt08's Avatar
It depends which tuner u get. I have an sct tuner with free bama tunes for life. They ask u 19 questions about your stang and they send you tunes. But if you add a mod to ur car you have to call bama and you download the new tunes from ur computer to the tuner. But the first time you dont need to download from ur computer.
Old 06-19-2011, 02:21 PM   #7
wc3john's Avatar
Someones got stuff from American muscle lol. Sorry to thread jack but how do you like the bama tunes?
As far as the speedo, it depends on the tuner but most have the option to select it from an option.
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 06-19-2011, 02:25 PM   #8
Jamesgt08's Avatar
I love the bama tunes. It took me less than 15 minutes to download new tunes after i called them for new tunes. And yea the sct tuner with bama tunes will fix you up and give you more hp gains.
Old 06-20-2011, 07:35 AM   #9
you have a speedo gear, its probably just messed up, if you have not replaced the rear end gears you just need a new gear, not sure which you have but they are cheap
Old 06-20-2011, 10:16 AM   #10
Jamesgt08's Avatar
He got 3.73 gears.
Old 06-20-2011, 10:41 AM   #11
3.73 it wont ever read 100% accurate as the speedo gears have teeth and the current one they recommend for 3.73 is like a 23 tooth or something~ it wont make it right.
You MAY can do a speedcal unit, its like 100 bucks~ plugs in between where the VSS sensor (speedo reader) on the transmission is and the computer. Snaps right in. You set it up and it takes the input from the transmission (speed) and modifies it to send to the computer/gauge. This calibrates it to read correctly.
Its what I did on my 01, just make SURE your 96 is compatable as some will and some wont work.
Mustang Parts & Accessories Superstore - 1800Mustang thats where I got mine from back in the day~ may have to give them a call to find out about it, its just a little box thing.
Old 06-20-2011, 10:59 AM   #12
vinnygt's Avatar
yeah i probably should give them a call.. so even if i get the tune it still wont be accurate? because i want to get the tuner but if that wont fix the problem then i might just hold back on that for a while until i get more mods because all i really have now are the 3 73 gears.
Old 06-20-2011, 11:00 AM   #13
tune can only modify 99+ vehicles, not pre 99 due to its cable driven on those not computer controlled so a tune wont help you speedometer calibration.
Old 06-20-2011, 11:04 AM   #14
Send a message via Skype™ to Texastboneking
Mine is a 97 model and is electronic not cable. So 96 will probably be the same. You can change to either the 23 tooth gear like I did. Cost round 20 bucks. Or you can pay for a tune.
Texastboneking is offline   Reply With Quote
Old 06-20-2011, 11:11 AM   #15
the speedcal will work on cable setups as well I believe but cant remember, worth a call as 23 tooth wont be accurate, and you cant do it in the tune pre 99
Old 06-20-2011, 11:17 AM   #16
vinnygt's Avatar
im just gonna call for the speeedcal.. if it works then im going for that one.. im better off doing that rather than not knowing how fast im going and having to use that as my excuse for the police. lol.
Old 06-20-2011, 11:18 AM   #17
The 23 seams accurate enough. But maybe my tire size makes it closer to accurate.
Old 06-20-2011, 11:26 AM   #18
vinnygt's Avatar
yeah i think my tires are also what might be throwing off the speed so much
1996 mustang
1996 Ford Mustang GT mrc Member Garages 0 06-15-2011 12:01 PM
1996 mustang? mustangmadnes09 General Car Discussion 6 09-04-2008 11:31 AM
1996 Mustang HELP! roadfeet Pre-2005 V6 Mustang 2 04-23-2006 06:16 PM
1996 Mustang GT Buzz 1996-2004 Mustang GT 1 04-22-2006 12:48 PM
06:19 PM
