Trans question - Mustang Evolution
Old 06-20-2011, 07:04 AM   #1
04machazblue's Avatar
Trans question
Okay so my car is having a little problem shifting from 1-2-3 I had this problem befor e with the stock quadrant went and got adj cable steel quadrant and all put it on adj and was fine. Okay so I am having the problem again it's bin 20,000 miles u think its time to adj it again I did a little helped a little. I was also thinking it's time to change the fluid again some better fluid also any inlet would be great the clutch is new 20,000 miles ago ram hdx clutch
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 06-20-2011, 07:12 AM   #2
Re: Trans question
define "same problem"
Old 06-20-2011, 08:07 AM   #3
Having trouble shifting into gear on stock quadrant
Old 06-20-2011, 01:15 PM   #4
Re: Trans question
do you have to push the clutch petal to the floor before it lets you shift? you may have to much slack in the cable.
Old 06-20-2011, 01:21 PM   #5
Yea I do I came to the conclusion on the way home from break at work I tried to get on it a little bit no dice lol yea I am going to
Adjust it as soon as I am home
Old 06-20-2011, 01:25 PM   #6
Re: Trans question
if its an aftermarket cable it could be stretched and thats your problem, go OEM cable if you dont have the OEM quadrent then you will need a firewall adjuster and take the slack up good.
Old 06-20-2011, 01:29 PM   #7
I can still adjust the cable a lot, I got the firewall adj already. As in there is a lot
Of tread left on the adj cable I have so I am going to try that when I get home from like now
Old 06-20-2011, 02:06 PM   #8
Re: Trans question
the petal should be firm at the top and only take .5-1 inch pushing in before the rpms start to clip (hold gas stead and ease clutch in going down the road in gear)
Old 06-20-2011, 03:23 PM   #9
Yea just was under the car cable is stretched so I called American muscle were I got it and they area sending me a new one for free!
Old 06-21-2011, 02:03 PM   #10
Old cable could be my problem hasha
Old 06-21-2011, 02:10 PM   #11
Re: Trans question
that an oem cable? if not go oem
Old 06-21-2011, 02:55 PM   #12
No it's not and American muscle sent me a new one for free I put it in already so I will get one soon though
Old 06-21-2011, 03:28 PM   #13
Re: Trans question
sounds good
00 3.8L trans help!!! jaiveson Pre-2005 V6 Mustang 5 02-21-2009 07:55 AM
manual trans question andreas 1979-1995 Mustang GT 3 04-26-2007 12:25 PM
New 5.0L Trans. TBone 1979-1995 Mustang GT 0 05-04-2004 08:47 PM
trans am.... lowflyn Pre-2005 V6 Mustang 7 01-06-2004 09:28 PM
Trans Am GT??? .:DarkEntity:. The Bar 10 09-17-2003 03:17 PM
06:02 PM
