96 gt wont run for crap. help - Mustang Evolution
Old 06-20-2011, 02:53 PM   #1
mhobbs's Avatar
ok i have a 96 mustang gt and 3/4 of the time it will idle in neutral and park(its automatic) only idles about 1/2 the time in drive wen stopped at like a light or stop sign itll waver from around 800 rpm to 500 but rarely die. goes down the highway smooth once you get to speed. but on acceleration sometimes it wants to sput then take off if u punch the gas too fast. usually will hesitate around 2500 rpm then shift up and take off. idk whats wrong iv ran gas treatment replaced fuel filter replaced plugs and air filter the coils are six months old and and so r wires what to check next?
mhobbs is offline   Reply With Quote
Old 06-20-2011, 04:17 PM   #2
mrc
mrc's Avatar
Try cleaning your iac valve and cleaning your maf sensor.
PI intake manifold swap,Stack racing CAI, Lawson Incinerator mufflers, SCT tuner.
mrc is offline   Reply With Quote
Old 06-20-2011, 09:27 PM   #3
jbanks's Avatar
I had this same problem, received the same advice, problem solved. Hardest part was finding my T20 Safety Star Drive to take the MAF out.
Boom!
jbanks is offline   Reply With Quote
Old 06-20-2011, 09:56 PM   #4
Jamesgt08's Avatar
Yea i had the same problems too. Just clean ur MAF and IAC valve. Thats a good place to start.
Jamesgt08 is offline   Reply With Quote
Old 06-23-2011, 05:26 PM   #5
nickysixx's Avatar
Re: 96 gt wont run for crap. help
Check for Vac Leaks aswell, if you dont have a vac leak clean out your iac and MAF. I redid all my Vac lines because mine were starting to dry out (I also have a 96 GT) that used to have the same issue. All these things caused me to stall out being stick it was super dangerous because on off ramps it would stall out. I also changed plugs and wires wich stopped alot of it.
nickysixx is offline   Reply With Quote
Old 06-23-2011, 08:22 PM   #6
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Just get some MAF cleaner spray, take the whole piece out of the intake ducting, and spray it....no need to remove the star screws.
Also, clean the IAC. Cheap and easy.
If that's not it, find the vacuum leak lol
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-23-2011, 08:56 PM   #7
jbanks's Avatar
-Will
The safety star drive tips are $6 for a full set at auto zone. Might as well buy them while you're picking up the MAF cleaner. Seriously, the whole piece is cleanable and probably needs it.
Let us know how if it works!
Boom!
Old 06-23-2011, 09:39 PM   #8
Send a message via Skype™ to Texastboneking
You realize that you can take the hose clamp loose and spray the maf from inside the tube right?
Texastboneking is offline   Reply With Quote
Old 06-23-2011, 09:43 PM   #9
Yeah....I wouldn't advise that
-Will
Waffles
Old 06-23-2011, 09:44 PM   #10
-Will
Why not. Just take the mad off and spray the he'll out of it. Works for me
Old 06-24-2011, 10:54 AM   #11
jbanks's Avatar
Sure, that's ONE way of doing it and I'm sure it works just fine. But it doesn't hurt to actually take the MAF out and do it right. With it out of the tube you can inspect it and clean it from all sides. We're talking about a $6 tool, not hundreds of dollars.
Boom!
Help It Wont Start... kack85 Pre-2005 V6 Mustang 5 07-28-2009 07:14 AM
wont start !!! too fast Pre-2005 V6 Mustang 7 04-24-2009 07:26 AM
wont start???? bluestang1724 1979-1995 Mustang GT 11 01-04-2008 09:10 AM
Wont be here Tuesday coolstang The Bar 7 05-31-2005 06:53 PM
i wont be around for a while Zim The Bar 13 12-24-2003 03:15 PM
10:12 AM
