I wanna go FAST! - Mustang Evolution
Old 06-21-2011, 07:45 AM   #1
CodyNelson's Avatar
Region: West Virgina
I wanna go FAST!
Within the next year and a half or so my GT will no longer be my DD. I will be starting into alot of engine work and I want some opinions. I am looking to either build up my 2V or swapping out for a 4V. If I keep my 2V I am looking at Heads, Cams, and maybe supercharger, etc. But what would you guys suggest. Should i save my money now and do a swap later or go ahead and start putting parts into my 2V piece by piece?
Old 06-21-2011, 08:46 AM   #2
Re: I wanna go FAST!
well the final result needs to be thought of now in a realistic manor. Some say "twin turbo 1500rwhp!" when not actually thinking how horrible that would be as a street car/daily driver.... so you should decide what you really want out of the car and the best way to go about it.
I think for a street car 400-500rwhp is about the limit~ any more and its for bragging rights honestly... at least on a 3500lb~ Mustang.
The 4v 03/04 cobra motor is easy to get there, no building needed, but... its HEAVY so thats a down side etc, little things like that.
What is your budget, you dont want the car to be down for 4 years and such~
Old 06-21-2011, 09:11 AM   #3
CodyNelson's Avatar
As far as a budget i really dont have one. Just looking at the cheapest and most cost effective way to get up to about 500 rwhp. I agree, any more than that is just too much to drive around alot
Old 06-21-2011, 06:17 PM   #4
Keep in mind the 03/04 Cobra engine is forged...I believe that is the only 4v that is. I think the Machs and N/A Cobras aren't, if I'm wrong do correct me.
I personally would feel much better with forged guts under the hood, especially going FI shooting for a higher hp goal.
I've seen complete 03/04 Cobra engine/transmission/wiring/ecu for sale for ~10k.
You might be able to build and force induce your 2v for that money. I'm not 100% sure on the options/pricing out there for 2v's these days.
I know a lot of guys have built up their 2v's and made some good numbers.
Hopefully some people with some experience with 2v's will chime in.
Old 06-21-2011, 06:26 PM   #5
Loc: Austin,TX
Forged 4V with a blower. To much money to get that 2V where you want it and stay safe.
Old 06-21-2011, 07:16 PM   #6
CodyNelson's Avatar
The 03/04 Machs are forged as well. But like you I hope someone with more knowledge on 2Vs will put in some input
Old 06-21-2011, 09:06 PM   #7
t0t4lbl4ck0ut's Avatar
The major issue with the 2v is the fact that the internals aren forged. You really can't go much further the bolt ins without risking a catastrophic failure without regutting it. It cost alot to get good numbers out of a 2v but Fir the cost of the cobra motor you can do cams, heads, pistons, rods, crank, and supercharge it and your down the same money and actually have alot more power. Mm&ff did a 2v engine from a 97gt and did exactly that and ran 717rwhd so numbers aren't the a problem.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 06-21-2011, 09:09 PM   #8
Oh how I hate phones correcting you "wrong" words lol
Old 06-21-2011, 09:23 PM   #9
Stupidfast5.0's Avatar
If you want 500 rwhp then just stick with the 2v. You can buy rods and pistons relatively cheap. Then, you just need a medium sized head unit of your choice, Procharger, Paxton, Vortech, etc.
2011 Mustang GT Premium, M6, Procharged.
Stupidfast5.0 is offline   Reply With Quote
Old 06-21-2011, 09:32 PM   #10
Yea exactly. The only reason you would want to go to the 4v would be to get like 1000hp. The 2v maxs out around 800 to 850
Old 06-21-2011, 09:41 PM   #11
I saw one a few weeks ago that made 1100 rwhp. Even the tuner said that was the baddest 2v he had ever seen!
Old 06-21-2011, 09:45 PM   #12
Well I'm talkin realistic lol my uncle built a racing 2v that was sc and turbo and made 1100rwhp
Old 06-21-2011, 10:04 PM   #13
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Mach's do not have the same short block, and they do not have the same forged parts.
You need to decide what your goals are. If you want to make anything 600 HP or less, I say just stay 2V. If you want to make more, then go 4V.
Honestly, you shouldn't need to spend $$$ on aftermarket 2V heads. Ported PI heads, purpose ground cams, the proper intake, a quality shortblock, and a blower or turbo should pretty easily get you 450-600 depending on how much boost you make, the tune, etc...
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-21-2011, 10:06 PM   #14
After re-reading this thread, I want to point out that 03/04 Cobras were the first 4V's to have a forged short block. Prior 4V's did have a good block (aluminum teksid) and a forged crank....but the rods/pistons were not.
Just FYI
-Will
Waffles
Old 06-21-2011, 10:08 PM   #15
Send a message via Skype™ to Texastboneking
Just FYI
-Will
So when I boost my 01. I'm sol?
Texastboneking is offline   Reply With Quote
Old 06-21-2011, 10:09 PM   #16
lol, didn't I tell you this a while back? You are limited to around 450 rwhp.
Old 06-21-2011, 10:11 PM   #17
You might have mentioned something.. 6-8 psi was where I was planning at staying. Whatcha think? I'm familiar with engines and superchargers. But not with engines that were not originally designed for a supercharger.
Old 06-21-2011, 10:12 PM   #18
Loc: Austin,TX
Yup had that same motor in my 99 cobra and it was one of the reasons I moved on.
Old 06-21-2011, 10:15 PM   #19
I'm perfectly happy with 450hp. But what is a safe yet effective boost level?
Old 06-21-2011, 10:15 PM   #20
Honestly, you can't go by PSI, as that could change depending on your headers, cats or o/r pipe, blower, etc. You will be good to go up to 450 rwhp and around 500 lbs of torque.
Old 06-21-2011, 10:16 PM   #21
Not necessarily.....It all depends on what you want to do. You could pretty safely make 430-450 and run forever with a solid tune. My old 97 Cobra made 45x on a stock shortblock and a Vortech T-Trim on 10 lbs. It ran fine, didn't get hurt until the guy who got it from me tried pushing it to 48x HP and running it hard without sufficient cool down time
-Will
Waffles
Old 06-21-2011, 10:16 PM   #22
Factory exhaust manifold. Off road xpipe. Getting the blower setup off a 04 cobra.
Old 06-21-2011, 10:18 PM   #23
He's right.....if you'd be happy with 450 RWHP, this would be my advice...
Before you install the blower, get COMPLETE supporting mods. Heads, mid-pipe, catback, larger TB, quality MAF, aftermarket fuel pump, possible KB BAP, and injectors (not installed until blower is)....
If you do all of those mods and get a typical centrifugal on 8 lbs. or so, a good tuner should be able to safely tune the car to 430-450 RWHP
-Will
Waffles
Old 06-21-2011, 10:19 PM   #24
-Will
450 is about where I want. I was originally shooting for 500 but I'll be happy with 450. It's my daily driver so I need it to be somewhat safe on the motor. I just would like to be sure no Camaro ss is gonna take me. Well. At least the stock ones.
Old 06-21-2011, 10:20 PM   #25
Get headers, it'll pay off.
You may want to also consider 96-98 Cobra cams.
Also, if you're serious about making as much HP as you can safely, get the blower ported while it's between vehicles. Also, get a SBTB and aftermarket or ported plenum. Posi Port has proved better results from porting than anybody else, so that'd be my advice.
-Will
Waffles
Old 06-21-2011, 10:21 PM   #26
-Will
Agreed, without the supporting mods I doubt he will get 450 out of the eaton at 6-8 psi.
Old 06-21-2011, 10:21 PM   #27
-Will
My 01 motor already has the correct heads. I'm getting the blower, injectors, intake, tb, alternator, intercooler. And any other little thing I might need off of a 04 cobra
Old 06-21-2011, 10:22 PM   #28
Your car with 400 RWHP from a roots style blower should not have any trouble whatsoever with any stock Camaro SS.....and realistically it should handle any Corvette with less than an LS3
-Will
Waffles
Old 06-21-2011, 10:22 PM   #29
nickysixx's Avatar
Haha, my friends z28 that has 24,000 miles on it at stock hp which is like 330 or something he wants to race me but he has better power to weight ratio. He's 600 lbs lighter than me, that's why I'm aiming for 450-500 aswell. I hate people who's parents buy them there cars when they no nothing about them.. -.-
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 06-21-2011, 10:25 PM   #30
I meant headers, sorry.
Don't use the Cobra injectors, just get some Ford Racing 42's. 03 Cobra injectors will require adapters in your car anyway, and 42's would support more power.
I would have the stock blower, TB, and plenum all ported by Posi Port. It will put you in the position to get the most out of your setup....or shop SVTP for a used, aftermarket TB and plenum (sell fairly often there).
Get an upgraded heat exchanger, the stock one is not very efficient.
You will need a coolant reservoir for the IC and an IC pump
-Will
Waffles
Old 06-21-2011, 10:25 PM   #31
I would also ditch the cobra heat exchanger. Get the biggest one you can afford. Cooler IAT's are much easier on brittle shortblocks.
Old 06-21-2011, 10:26 PM   #32
Sniped by K.F. Mohawk
Old 06-21-2011, 10:28 PM   #33
-Will
Good advice but keep this in mind. Everything I take off this 04 is free. This is kind of a budget deal for me. The tune is going to cost me 400. I'm trying to get out as cheap as possible. If I use the 04 cobra heat exchanger should I shoot for 400hp?
Old 06-21-2011, 10:29 PM   #34
Cheap, Fast, Reliable.
Pick two. Our unfortunate reality.
Old 06-21-2011, 10:30 PM   #35
330 is OE rated at the crank.....not RWHP. Your car with 350 RWHP would have him covered easily
-Will
Waffles
I wanna know why... Blackedout Pre-2005 V6 Mustang 11 04-19-2011 08:56 AM
I wanna go fast ponyboy94 Pre-2005 V6 Mustang 33 12-30-2010 11:48 PM
I wanna go fast(er)? v0nz General Mustang Discussion 47 12-12-2010 09:06 AM
fast and furious 3- fast food run Kyle The Bar 7 04-13-2006 12:56 AM
Somebody wanna help me out? drummerstang98 The Bar 0 09-13-2004 10:54 AM
09:41 AM
