what do i need? - Mustang Evolution
Old 06-21-2011, 06:26 PM   #1
98gtdriver's Avatar
what do i need?
I want to do a auto to manuel swap in my 98 gt. What do I need? Obviously the tranny but what else?
-Eric
98gtdriver is offline   Reply With Quote
Old 06-21-2011, 06:34 PM   #2
Jamesgt08's Avatar
I have the list on my thread i started.
Jamesgt08 is offline   Reply With Quote
Old 06-21-2011, 06:37 PM   #3
Jamesgt08's Avatar
Change the pedal asy 4 bolts take the shifter out and insert shifter boot plastic, clutch cable. One pop out piece of metal on fire wall, trans brace, drive shaft knuckle, tranny harness . Clutch and flywheel and tranny. Done.
Old 06-21-2011, 10:13 PM   #4
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: what do i need?
Listed already, it's not really that bad....hardest part is the pedal assy. IMHO
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-21-2011, 10:18 PM   #5
nickysixx's Avatar
If you buy a rebuilt tranny on eBay that's in good condition and say its for a swap and it comes from a legit shop they usually tell you what's needed and basic instillation directions.
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 06-21-2011, 10:45 PM   #6
98gtdriver's Avatar
I think I can get a set up for cheap from a guy at work
-Eric
Old 06-21-2011, 10:48 PM   #7
nickysixx's Avatar
How much is cheap and how many miles are on it also if its rebuilt or if he says it is check for res or corrostion around every seal. Make sure you know what your buying before it turns into a head ache. Just looking out for your satisfaction. Also what trans is it? Tremich?
Old 06-22-2011, 07:13 AM   #8
Re: what do i need?
might be VAR cheaper to sell your car and buy a 98 cobra or so~ in the end that is
Old 06-22-2011, 06:06 PM   #9
98gtdriver's Avatar
Would a 96. Tranny fit with my 98?
-Eric
Old 06-22-2011, 06:15 PM   #10
nickysixx's Avatar
Has long as it came from a Gt. It's the same car. Bolts should line up during the conversion
Old 06-22-2011, 06:17 PM   #11
98gtdriver's Avatar
Thanks!
-Eric
Old 06-22-2011, 06:21 PM   #12
nickysixx's Avatar
Thanks!
If yours is a 4.6 and the trans is from a 4.6 and not from the 5.0 (94 and 95)
Old 06-24-2011, 01:04 AM   #13
98gtdriver's Avatar
Anyone have a clue about the price to install everything?
-Eric
Old 06-24-2011, 01:28 AM   #14
wc3john's Avatar
Don't forget about checking driveshaft geometry to the rear-end. I've been in a 5.0 swapped 4 cylinder fox and the didn't check the geometry and he broke the driveshaft while cruising.
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 06-24-2011, 01:54 AM   #15
98gtdriver's Avatar
Im going to have a shop do it depending on the cost. The shop is for mustangs only so ill make sure I have everything
-Eric
Old 06-24-2011, 03:44 AM   #16
Jamesgt08's Avatar
Well i started on my swap yesterday. I got the tranny out and stuff. Ima finish it up today. Its going pretty good so far.
Old 06-26-2011, 11:33 AM   #17
98gtdriver's Avatar
Originally Posted by Jamesgt08
Are you gonna do it yourself or have someone do it?
Ill have a shop do itdepending on the cost... I don't need a new edu? I have a Sct tuner
-Eric
12:44 AM
