Need a radiator reccomendation. - Mustang Evolution
Old 06-28-2011, 02:04 PM   #1
Long spry short, I am rebuilding an '02 GT turbo. The turbo mounts in front of the passenger side of the motor. I want a little more room between the turbo and the fan. Anyone have any suggestions on where to start looking for a high efficiency slim radiator?
natm02 is offline   Reply With Quote
Old 06-28-2011, 02:07 PM   #2
Send a message via Skype™ to Texastboneking
If you can get a front mount fan that blows backwards. Itll give you room
Texastboneking is offline   Reply With Quote
Old 06-28-2011, 02:24 PM   #3
That's a good idea, that I never thought about. Probably cheaper then a custom radiator too. Thanks.
Old 06-28-2011, 02:28 PM   #4
Your welcome!
Old 06-28-2011, 05:42 PM   #5
onesickstang01's Avatar
Mishimoto makes many push/pull fans. The only thing is that our fans stock pull about 3000-3500 cfm which is alot of air to move. Most fans will not move that much, not to mention we have dual speed fans that are also linked with our ac systems. Most likely you will need multiple fans. Pushing and pulling
onesickstang01 is offline   Reply With Quote
Old 06-28-2011, 06:38 PM   #6
Nah. You can make any fan push or pull. And you van also Tie in the ac just as easy.
Old 06-28-2011, 07:07 PM   #7
Yes but what im saying is to move the cfm of the stock fan you will need both a push and a pull fan
Old 06-28-2011, 07:13 PM   #8
Don't know why fans your looking at. The one I used pushed more air than my oem fan did on high
Old 06-28-2011, 07:33 PM   #9
Some of the best oem fans are 99+ mustang. Taurus mark viii and viper. They all pull between 3000 and 5500 cfm which is very high. Most aftermarket sblade fans only move 1800 to 3000
Old 06-28-2011, 07:48 PM   #10
Re: Need a radiator reccomendation.
oem fans pull more than necessary. they stay on low speed for most of their oporation unless you turn the ac on. but there are plenty aftermarket fans that he could get that would front mount and cool just fine
Old 06-29-2011, 09:46 AM   #11
I destroyed my radiator getting the old motor out. So, I need both. There has got to be a radiator/fan combination that will give me room and keep me cool.
06:21 AM
