P/n- N606063-S2 - Mustang Evolution
Old 06-30-2011, 07:03 PM   #1
P/n- N606063-S2
Can someone decipher this part number please? It's the bolts for the bell housing to the block on an '02 manual GT. I need 6.
My best guess is M10x66mm.
natm02 is offline   Reply With Quote
Old 07-01-2011, 09:38 PM   #2
Go to www.fordparts..com and type in the part number. You can also buy them from them.
mudduck7 is offline   Reply With Quote
Old 07-02-2011, 05:09 PM   #3
Well... I tried that, and it usually works. It's not this time. I usually get the specs then go to the local Fastenal dealer. $6.00 from Ford Vs. .30 from them.
Old 07-02-2011, 05:13 PM   #4
Send a message via Skype™ to Texastboneking
Re: P/n- N606063-S2
hate to tell you but your just gonna have to buy these bolts from ford. i had to too. the thread was a 10 mm by 1.5 but the problem is the bolts head. its shorter and a smaller size than what you can get at fastenal. it is truly a specialty bolt that you need to get from ford. not to mention its a higher grade steel. you dont want to try and rig a flywheel to clutch bolt. you can have some nasty problems if they give out.
Texastboneking is offline   Reply With Quote
Old 07-02-2011, 08:53 PM   #5
Ok. That sucks, but your right.
08:14 AM
