pi intake manifold - Mustang Evolution
Old 07-08-2011, 01:25 AM   #1
vinnygt's Avatar
pi intake manifold
what are the gains?
vinnygt is offline   Reply With Quote
Old 07-08-2011, 09:02 AM   #2
stangstar92's Avatar
Originally Posted by vinnygt
what are the gains?
Not too noticeable, if you the aluminum one and have it ported and polished then you will get a high increase in power more so than just the standard plastic FRPP intake manifold.
2002 Gt Mustang - Built 2 Valve
"Real cars don't power the front wheels...they lift them"
stangstar92 is offline   Reply With Quote
Old 07-08-2011, 12:35 PM   #3
ksrumbel's Avatar
Nada. Unless you have supporting mods suchas cams, tb, plenum
ksrumbel is offline   Reply With Quote
Old 07-08-2011, 12:37 PM   #4
mrc
mrc's Avatar
The gain is 15+. If you have a tune done afterward it is closer to 40. All that is if you have a none PI motor of course. I have it done to my car. The difference is really great.
PI intake manifold swap,Stack racing CAI, Lawson Incinerator mufflers, SCT tuner.
mrc is offline   Reply With Quote
Old 07-08-2011, 12:43 PM   #5
Send a message via Skype™ to Texastboneking
Re: pi intake manifold
not much if you dont use the pi heads too
Texastboneking is offline   Reply With Quote
Old 07-08-2011, 12:53 PM   #6
mrc
mrc's Avatar
Cheaper to just get the PI cams. Its an additional 15 horses or so. If you do the whole head swap it also raises your compression. It gives you more power then the PI engines but the cost isn't near as low as people make it out to be.
The gains you get from just the manifold swap is well worth the money you pay. The gains are also much higher then people say. If you ask people who have done the swap,like myself,you will find they got a large,noticable difference. I did the swap,cai,and tuner. The difference is night and day. My car screams through the whole rpm band. Its not like getting an actual power adder but for the money its worth it. You also get better gains from any other engine mods you add later.
Old 07-08-2011, 12:59 PM   #7
I've done the swap
15hp isn't that easy to feel in the seat
Pi head swap isn't that expensive if you do it yourself
And the reason you felt a big gain is because you did the swap while putting a tuner on it. The cai did very little for you.
The tuner did the most for you
The intake did little
Old 07-08-2011, 01:12 PM   #8
mrc
mrc's Avatar
You having a bad day,boneking? The swap with the tuner gives you a large hp gain. Which is what I said in the first place. Again its not like a real power adder,but for the money the gain is really good. Most people cant do a head swap by themselves. The cost is high. I did the research and talked to a few shops. Just to get the heads can be expensive when you don't have connections. For around $800 you can get around a 40 hp gain or for close to $2000 (all the parts that I would use for a head swap) you can gain around 80+.
Old 07-08-2011, 01:15 PM   #9
not a great day.. things on my mind...
but i just dont want to give the guy false numbers. 40 hp is a lot for a tuner and an intake to make. thats all im getting at
btw i have a set of 4v heads for sale
Old 07-08-2011, 01:20 PM   #10
mrc
mrc's Avatar
I agree. I dont feel I'm giving false numbers though. I did a lot of research before buying and installing the parts. Hopefully your day gets better. I'm on vaca and all relaxed.lol. I didn't think you could put 4v heads on a 2v block. What all is needed to do that swap?
Old 07-08-2011, 01:27 PM   #11
you can but it wont do a ton for you. your bottom end cant turn 7000rpms to get the max power out of them. they will fit though.
and what a site claims vs what a dyno shows is a big difference.
for example flowmaster claims up to 15 hp when you use thier mufflers.
dyno shows 1-3 maybe
same with k&n filter claims
Old 07-08-2011, 01:35 PM   #12
mrc
mrc's Avatar
That's what I was thinking. The bottom end isn't built to take advantage of the 4v heads.
I never go buy what company's claim for horsepower. I did the build that was recommended and they had dyno sheets backing up the claim. The intake by itself didn't add that much but when they added their 93 octane tune the numbers hopped up. I couldn't tell any real difference with cai other then the motor sounding better and the whole whistling sound when on the throttle and air discharge sound when you let off. That was cool I guess.lol. their sheets also showed a pretty big increase with a full catback added but again that had the swap and tune with it. I think it was around like 13 hp or something like that.
Also don't forget. I have a 96 and that motor and 97 motor had the least amount of power of any 4.6. They gains seem to be a bit better then the 98 and then PI motors. Again that's just what I have found from research.
Old 07-08-2011, 01:40 PM   #13
Guess I need to take that one I did the pi swap back to the tuner lol. My friend only got around 25-30 rwhp.
Old 07-08-2011, 01:48 PM   #14
mrc
mrc's Avatar
Dynos are all different. That's probably the number difference. Whether I got 30hp or 40hp the car runs better,pulls harder,and actually sounds like it has balls. It'll do untill I can get a motor swap done. Please by no means think that I think my car suddenly became all fast and badass by this swap(because it ain't),but I do feel it was worth the money.
Old 07-08-2011, 01:59 PM   #15
Lol ok. I know it's worth the money just disagreed with your numbers its all good
Intake Manifold vs Intake Man-child jbanks 1996-2004 Mustang GT 17 08-02-2011 04:55 AM
Roush Cold Air Intake for 2011 5.0? dailey 2011-2014 Mustang GT 4 07-07-2011 01:57 PM
For those that have installed the Boss Intake dailey 2011-2014 Mustang GT 14 07-05-2011 02:08 PM
5.0 Intake cover RED! wnt2gofst Mustang Parts for Sale and Wanted 2 07-04-2011 11:11 PM
broken lower manifold bolts shustwit Pre-2005 V6 Mustang 8 06-29-2011 12:02 PM
» Members Mustangs
Peri
Befought
Trouble
diffle
Add your Mustang
07:06 AM
