New Shifter.....No Backup Lights Now! - Mustang Evolution
Old 07-08-2011, 10:03 PM   #1
jjsg09's Avatar
I put in a steeda tri-ax shifter in my 02 GT and now no backup lights. What do I do?
Old 07-09-2011, 12:36 AM   #2
Send a message via Skype™ to Texastboneking
Shifter adjusted correctly???
Texastboneking is offline   Reply With Quote
Old 07-11-2011, 07:44 AM   #3
jjsg09's Avatar
What you mean by that is it adjusted correctly? I adjusted the shift stops how the instructions say.
Old 07-11-2011, 07:46 AM   #4
The reason I ask is because the switch is in the transmission. And if you shifter isn't engaging reverse enough the switch will not be activated.
Old 07-11-2011, 09:18 AM   #5
jjsg09's Avatar
Well it engages reverse but no lights I will try to adjust and see if it helps.
Old 07-11-2011, 09:31 AM   #6
It could be engaging but just not far enough to engage the switch.
Old 07-11-2011, 09:59 AM   #7
jhagan1980's Avatar
Or your switch could've gone bad at the same time. Less likely but still could happen. Mine went bad, about $30-$40 at the stealership, and not hard to change out.
jhagan1980 is offline   Reply With Quote
Old 07-11-2011, 10:05 AM   #8
Re: New Shifter.....No Backup Lights Now!
back off the shift stops so there is no change the handle will touch them, they are rather useless anyway as the trans has internal stops.
Old 07-11-2011, 10:23 AM   #9
This is only true in our T56's if I remember right. T5's and T45's do not have built in internals.
Old 07-11-2011, 04:13 PM   #10
jjsg09's Avatar
Mine is the T3650
Old 07-11-2011, 04:26 PM   #11
Originally Posted by jjsg09 View Post
Mine is the T3650
Still think I remember it being the T56 is the only one with internal shift stops. But, I could be wrong. The shifter instructions would have told you NOT to use the stops had the transmission it's designed for had internals. Just like the instructions for the T56 shifters do.
Old 07-11-2011, 05:18 PM   #12
onesickstang01's Avatar
3650 has internal stops
onesickstang01 is offline   Reply With Quote
Lights? NYmustang5 Pre-2005 V6 Mustang 3 07-08-2011 01:43 PM
Shifter advice Qwik Four Six 1979-1995 Mustang GT 8 07-08-2011 08:58 AM
fast blinker - lights all good sattwood General Mustang Discussion 2 07-04-2011 08:01 PM
WTB/ short throw shifter 93stang306 Mustang Parts for Sale and Wanted 0 06-25-2011 08:10 PM
07:57 PM
