My 6 disc OEM CD player bad - Mustang Evolution
Old 07-11-2011, 04:16 PM   #1
jjsg09's Avatar
My factory cd player says that all 6 disc slots are full but there is no CDs in it. It just says cd error when I want to load one???
Old 07-11-2011, 07:01 PM   #2
junoS197Bl08's Avatar
Re: My 6 disc OEM CD player bad
did u try pressing the eject button on all 6 slots doubt that will work but its worth a try. Also try disconnecting the battery for a while and that will basically reset everything. So hopefully that will work.
Then if that doesn't work. Is it under warrantee? If it is under warrantee then take it into ford and have them fix it. But if its not under warrantee then I would start looking into aftermarket head units rather than buying a new OEM one.
2008 V6 Windveil Blue with 5spd standard transmission-pony package, replica rims, shorty antenna
junoS197Bl08 is offline   Reply With Quote
Old 07-11-2011, 07:28 PM   #3
sally2002's Avatar
I just had my 6 disc go out on me also and to get a new one from ford it will cost around 500 dollars for a new head unit and to me thats pretty salty. I would go aftermarket. Thats what my plans are and find one that is iPod capable and more for half the price but that's my opinion.
sally2002 is offline   Reply With Quote
Old 07-11-2011, 08:51 PM   #4
Not sure if you have the Mach system (94-04) or the Shaker (05-present). The Mach 460's 6 disc are known to go out. The loading unit wears out and it's ~315 for a remanufactured unit with your old one sent in as a core.
If you can live without the 6 disc and Mach head unit, go aftermarket.
I haven't heard too much about the Shaker systems going bad, but I guess it can happen.
Old 07-11-2011, 11:11 PM   #5
vinnygt's Avatar
mach 460 sucks...if im playing a cd the damn thing cuts off on every bump.
vinnygt is offline   Reply With Quote
Old 07-12-2011, 12:06 AM   #6
03GT88's Avatar
My mach 1000 did the same crap in my 03. Wouldn't load when it did it said cd error. Wouldn't eject and so on. I took it out unplugged it and put it back in. That didn't help. So then I took it back out took off the outer cover of the unit to just see if I saw any broken parts. Didn't notice anything. I took my cds out and put it back in the car. It has been working great for probably 6 months. Don't know why it fixed the problem but it did. Its worth trying I say.
03GT88 is offline   Reply With Quote
Old 07-12-2011, 09:51 AM   #7
I had to replace mine because the volume would turn all the way up when I tried to turn it down.
Old 07-12-2011, 11:37 AM   #8
stampde's Avatar
yup my mACH460 KEPT DOING THE SAME THING , A couple years back ,sometimes disconnecting the battery works , other times it would just fix itself ,and cd's kept getting jammed too , i replaced it all ,with after market stuff ,sounds a lot better too!!!
2011 GT Auto
Old 07-12-2011, 11:51 AM   #9
Agreed I like my clarion better and it doesn't scare the crap out of me when I turn my car on.
Old 07-12-2011, 12:23 PM   #10
you can grab them cheap if you want a replacement head unit
Old 07-12-2011, 07:20 PM   #11
They aren't bad for stock. I was pretty happy with the system when it worked.
But it seems they don't have the longevity as a lot of them have issues after a couple years.
Old 07-13-2011, 12:25 AM   #12
Mine did that once, what you do is turn the car to accessory, then power off the radio. Turn your car off and unplug the neg cable for a few mins, then reconnect the cable, turn your car back to accessory and turn it on.....it should reset itself.
2002 GT Premium: A few bolt ons.
Dyno tuned by PSI Motorsports
255.67whp & 300.46wtrq
02gtkev is offline   Reply With Quote
Old 07-13-2011, 08:12 AM   #13
jjsg09's Avatar
Yea I've done everything but the battery cable thing. But I've completely have removed it out and taken the faceplate off an no CDs in it don't know y it still says it's full.
Old 07-13-2011, 08:16 AM   #14
jjsg09's Avatar
It's the Mach 460 it's was working great but the other day i turned it on and went to put a disc in and it says they are all full
Old 07-13-2011, 08:17 AM   #15
jjsg09's Avatar
Well I opened I up no discs in it and still shows all 6 slots full
Old 07-13-2011, 08:18 AM   #16
jjsg09's Avatar
What after market one did u go with
Old 07-13-2011, 09:02 PM   #17
jbanks's Avatar
Disconnect the battery and reconnect it. Should fix it. If not, throw it in the yard.
Boom!
jbanks is offline   Reply With Quote
Old 07-13-2011, 09:19 PM   #18
03GT88's Avatar
Sounds like there all pretty crappy ford should have done a Recall Haha.
Old 07-13-2011, 10:09 PM   #19
yeah the CD player in the truck went bad several times under warranty and finally we had to get an aftermarket one after the last time it broke....we went Clarion and it is nice but it doesn't match the instrument colors
2008Shelby is offline   Reply With Quote
« comp cams | 94 5.0 »
Bad luck... Blackedout Pre-2005 V6 Mustang 20 07-29-2011 07:50 AM
07:13 AM
