turbocharging my 4.6 help - Mustang Evolution
Old 07-14-2011, 09:43 AM   #1
Ok so I have a 2000 mustang with a older 4.6 out of a 97 mustang yes i know I took a HP drop but I pulled it to build it up and needed the car at the time anyway I'm building my own turbo kit I finished everything as far as fitment I will post pics when I go for the final build something I didn't think about till now is the maf sensor will the car run properly without it beings it already has a map sensor and if not what would I have to buy and and what would be the specs I would have to tune it to based on 6 psi 8 psi and 10 psi
itsfrito is offline   Reply With Quote
Old 07-17-2011, 07:24 PM   #2
Re: turbocharging my 4.6 help
it will start yes...will it idle like crap yes...the tune isnt set for the bigger injectors your going to have so your fuel table is going to be all over the place trying to idle...whats your setup? is it blow thru or draw thru?
slow02gt is offline   Reply With Quote
Old 07-18-2011, 07:23 AM   #3
you have to have it tuned including the maf and a/f dont run it much at all until its all calibrated.
« Cams | Cam types »
08:39 PM
