Cams - Mustang Evolution
Old 07-16-2011, 09:36 PM   #1
Cams
Will a a tric flow .580 lift cam for a 2V head will fit with 4.5cc dich pistons?????
charlie514 is offline   Reply With Quote
Old 07-17-2011, 07:27 AM   #2
mrc
mrc's Avatar
For PI heads or NPI? PI heads have much tighter valave clearance. Might be best to contact your local speed shop and discuss it with them.
PI intake manifold swap,Stack racing CAI, Lawson Incinerator mufflers, SCT tuner.
mrc is offline   Reply With Quote
Old 07-17-2011, 08:52 AM   #3
Any other opinions
Old 07-17-2011, 02:13 PM   #4
iwannagofast's Avatar
Re: Cams
hollar at trick flow tell what u got and what you want out of ur car and they will assist you
iwannagofast is offline   Reply With Quote
Old 07-17-2011, 07:19 PM   #5
Re: Cams
no...you will need notches in your pistons.... for the valves to clear...what is your setup...
slow02gt is offline   Reply With Quote
Old 07-17-2011, 08:54 PM   #6
Ok 4.5cc probe pistons standar bore. I want trick flow cams .580 lift, i have forged rods, stock stroke, 2 valve pi heads and some other parts. You think the .550 lift will be fine.
Old 07-18-2011, 06:13 AM   #7
Re: Cams
lift is not the only thing that matters duration does also when it comes to decided PTV clearence....i never really seen trickflow cams make great overral power...just ok PEAK power...give bullet racing cams a call and have them spec you out some...or there is foxlake,modular head shop,cms cams....since your cc is almost a flat top if you dont have valve reliefs and your running pi heads your only going to be able to fit a small cam in so you wont be able to take full advantage of your setup....especially if your running stock unported heads....email jim at cushman cams or email nick and modular head shop and they will be able to help...but your cam choices are very limited...
comp cams teksidtwovalve 1996-2004 Mustang GT 0 07-13-2011 12:12 PM
cams? 98gtdriver 1996-2004 Mustang GT 1 07-08-2011 03:56 PM
I wanna go FAST! CodyNelson 1996-2004 Mustang GT 61 06-24-2011 10:20 PM
08:24 AM
