Need advise. - Mustang Evolution
Old 07-18-2011, 08:44 PM   #1
Need advise.
I've a 97 GT with 207000 miles, I am looking into an 05-09 used motor to replace the old. My ?'s are how hard would this sit up be, and would the 05-09 gt 3V work w the auto I had rebuild that came with the 97?
drumming4fun is offline   Reply With Quote
Old 07-19-2011, 12:41 AM   #2
98RedGT's Avatar
The tranny would probably not work lol. And idk google a swap
ROOM FOR IMPROVEMENT
98RedGT is offline   Reply With Quote
Old 07-19-2011, 12:48 AM   #3
nickysixx's Avatar
Don't put a 3v in there, get a 99-04 motor and you should do the tranny too
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 07-19-2011, 04:52 AM   #4
Yeah I was thinking the 3v motor Mayb to much to hassle with, but wouldn't an 99-2004 motor fit RT to the auto tranny in my 97? Just spent a good deal to rebuild it don't wanna swap out the tranny unless I really have to.
Old 07-19-2011, 07:19 AM   #5
Re: Need advise.
its probably far easier to install a 4v 4.6L out of a cobra and end up with 300hp~ same basic end result... or buy an 03/04 cobra motor
Old 07-19-2011, 08:46 AM   #6
Ahh duh thanks spectorV forgot about the grt 4v motor. Now what about ecu and wiring harness? I know if I can strip an wrecked one I can get all that stuff, but if I buy an 4v motor from a salvage yard or from another state and they dont offer those things what would I do? Super new to this obviously lol
Old 07-19-2011, 08:57 AM   #7
Re: Need advise.
you will probably require a new harness and computer but I am not 100% sure on all of it~ one thing though to think about is in 96 for example it was not a coil on plug design I dont believe, used a coil pack setup for ignition, then later on maybe 99 they swapped to coil on plug design~ just something else to look into.
Also the mach 1 engines are basically the same as the cobras.
Old 07-19-2011, 09:21 AM   #8
wereKEV's Avatar
Re: Need advise.
Might be cheaper to just buy a new stang.
wereKEV is offline   Reply With Quote
Old 07-19-2011, 09:36 AM   #9
Jamesgt08's Avatar
Not cheaper. Just way less work. Lol
Jamesgt08 is offline   Reply With Quote
Old 07-19-2011, 10:30 AM   #10
Thanks spectorV giving me a lot of insight. As for a new stang already have a sweet 2006 GT All done up nicely, just wanna do some fancy stuff and learn new things as I go with the 97 GT.
Old 07-19-2011, 10:32 AM   #11
98RedGT's Avatar
I respect that. Post pics of both
Old 07-19-2011, 10:35 AM   #12
Re: Need advise.
you could keep it on the cheap and go with a PI swap for the 97 GT and rebuild the motor~
Old 07-19-2011, 10:44 AM   #13
Jamesgt08's Avatar
Yea just put a pi motor from like an 99-04 gt. And itshould work with your tranny.
Old 07-19-2011, 11:17 AM   #14
Re: Need advise.
the only down side using a 99-04 is you are still at 260hp where if you put heads on your 97 engine it will bump up the compression a bit and raise it up to around 285~ not a good or bad really just an FYI
Old 07-19-2011, 12:06 PM   #15
Awesome guys!! Thanks!! Say how do u put pics on here? I'm using my iPhone w this app.
Old 07-19-2011, 12:21 PM   #16
Jamesgt08's Avatar
Go to the top and hit reply and then hit attachments then u go to ur library and choose photo. Im on my iphone too
Old 07-19-2011, 12:41 PM   #17
The toys Ohh Abd a 2004 ZX 10 when my stangs can't do it lol
ID:	29052   Click image for larger version
ID:	29054   Click image for larger version
Old 07-19-2011, 12:42 PM   #18
Thanks jamesgt08
Old 07-19-2011, 02:27 PM   #19
Jamesgt08's Avatar
No problem. Very nice stangs by the way.
Old 07-19-2011, 06:05 PM   #20
Thanks say I put a new fuel pump in my 97 gt and the pump comes on when I turn the key but won't start just turns over won't start any suggestions?
Old 07-19-2011, 06:07 PM   #21
Jamesgt08's Avatar
Did you change the fuel filter ?
Old 07-19-2011, 06:21 PM   #22
Like two months ago, i changed to a 190 LPH over stock could thT b an issue?
Old 07-19-2011, 10:11 PM   #23
Lol had the red and black wires in the wrong place
Old 07-19-2011, 10:23 PM   #24
Jamesgt08's Avatar
Which red and black wires? Lol
Old 07-20-2011, 04:51 AM   #25
The wires that connect to the fuel pump for power. Works great when it's not wired in reverse ha!! The BBK after market 190 LPH fuel pump requires u to splice into the wires for thr plug in feature to the fuel pump. I had to many coors I guess
Old 07-20-2011, 04:59 AM   #26
Jamesgt08's Avatar
Ohh haha. Yea i bet it does work good if the wires are hooked up properly lol. I have to stop when i have to many beers or ill mess up something.
Old 07-20-2011, 05:44 AM   #27
Ha ha!! I was like a drunken Edward scissorhands with terrets and no ADHD medication!! Lol but it works fine now
03:08 PM
