MAF - Mustang Evolution
Old 07-20-2011, 01:17 AM   #1
t0t4lbl4ck0ut's Avatar
MAF
Ok I was reading that with a kenne bell 2.6 kit on my 02 gt that my 90 mm lightning maf won't flow enough air. I've read that this Maf can handle tons of power. Just curious if anyone else had a similar setup or anything and could shed some light on my issue
t0t4lbl4ck0ut is offline   Reply With Quote
Old 07-20-2011, 05:45 AM   #2
onesickstang01's Avatar
The 2.6 is huge but i wold be close depending on the pulley/boost. My 90mm lightning is almost maxed out with my si-trim vortrch with a 2.95 pulley and power pipe though
onesickstang01 is offline   Reply With Quote
Old 07-20-2011, 06:27 AM   #3
Well the 2.6 does 616 hp at 15 psi and cams and heads. Which I already planned on so I might as well just go with a 110 mm.
Old 07-20-2011, 08:22 AM   #4
Re: MAF
if your motor is not built then you wont need 15psi on it, probably want to keep it around 400-450rwhp at most with a spot on tune.
Old 07-20-2011, 12:53 PM   #5
It's built. The guy at kenne bell really sounded like I should get the 2.6 over the 2.1 because it would benefit me more with a built motor.
Car has a stumble RoadBlock 1996-2004 Mustang GT 22 07-12-2011 12:49 PM
MAF sensor Mustanglife Pre-2005 V6 Mustang 5 07-01-2011 07:22 AM
07:35 AM
