Car is trembling like it wants to turn off. - Mustang Evolution
Old 07-20-2011, 08:37 PM   #1
bobsurvives's Avatar
I recently replaced my intake manifold for my 2000 Mustang GT and my motor is trembling and shaking like it wants to shutoff... It doesn't do it all the time and at high speeds I have zero problems.
Anyone know what this could be?
bobsurvives is offline   Reply With Quote
Old 07-20-2011, 08:42 PM   #2
Re: Car is trembling like it wants to turn off.
Did you check to make sure there weren't any vacuum leaks? Sounds like a vacuum leak to me.
Old 07-20-2011, 09:30 PM   #3
I'll check that out... A friend just told me to disconnect the battery and re tune and that should stop the problem.
Old 07-20-2011, 09:34 PM   #4
Jamesgt08's Avatar
Yea check vacum lines. Maybe while u dissconnect battery check ur vacuum lines.
Jamesgt08 is offline   Reply With Quote
Old 07-21-2011, 05:47 AM   #5
onesickstang01's Avatar
Sounds like a misfire to me. Check all your coils and make sure they are firing. At higher rpms you wont notice a misfire
onesickstang01 is offline   Reply With Quote
Old 07-21-2011, 06:04 AM   #6
mrc
mrc's Avatar
Did you drain the coolant before you swapped the manifolds out? Its pretty common to get a bit of coolant in one or more of the sparkplug holes. Most commonly it is plugs number 4 and 8. Try pulling them and cleaning them off.
PI intake manifold swap,Stack racing CAI, Lawson Incinerator mufflers, SCT tuner.
mrc is offline   Reply With Quote
Old 07-21-2011, 07:22 AM   #7
sounds to me like a missfire as well, clean the maf and IAC as well regardless as it probably needs it
Old 07-21-2011, 12:46 PM   #8
I did not drain the coolant and a I removed the manifold, coolant fell everywhere.
Haha so I'll take out the spark plugs and clean them off.
What's the IAC?
what would cause a misfire?
Old 07-21-2011, 12:52 PM   #9
mrc
mrc's Avatar
What's the IAC?
IAC is your idle air control valve. It is on the front of your throttle body with a vacuum line running into it. Ya cant miss it. Just pull it off and spray the crap out of it with throttle body cleaner, then let the excess run off before you reinstall it. Also be careful with the gasket for the IAC,it is paper and tends to be brittle.
A missfire is caused when the sparkplug isnt firing at the right time or not firing at all. If you get coolant in the plug holes it causes a missfire because your coils have to send the spark through the wires and the coolant to fire the plug. This causes either a weak spark or no spark at thus causing the missfire.
Old 07-21-2011, 12:57 PM   #10
Ok, that sounds like exactly the problem that is going on with my car. I'm pretty sure my spark plugs are wet and there could be a vacuum leak. I'm gonna mess around with it today and I'll let you all know if I solve the problem
Thanks for the help!
Old 07-21-2011, 01:24 PM   #11
nickysixx's Avatar
Try not to get coolant into you cylinders. It takes a minute for everything to blow out.
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 07-21-2011, 05:18 PM   #12
Read the trouble codes with my turner and it says Misfire detected in Cylinder 4.
I've been running the car for a week with it bogging like this and no serious things have occurred. Bought a new set of Motorcraft spark plugs and I'm gonna replace all of them and reapply my diablo tune and let you all know how it runs (:
Old 07-21-2011, 06:11 PM   #13
mrc
mrc's Avatar
When I installed my PI manifold I got the same code. Pulled the plug and wiped it clean and cleaned the wire boot. Haven't had the problem since.
Old 07-21-2011, 06:42 PM   #14
Was your car bogging?
and my spark plugs haven't been changed ever, 11 years old... Thought it would be nice to hook my baby up with some fresh spark (:
Old 07-21-2011, 06:46 PM   #15
Jamesgt08's Avatar
Woww 11 years. I think its definently time for new spark lol
Old 07-21-2011, 06:49 PM   #16
Haha yeah, but these spark plugs have held up for a good long while. I give them props for all their hard work!
Old 07-21-2011, 07:02 PM   #17
mrc
mrc's Avatar
Yeah it bogged real bad,but if you haven't changed them in 11 years it would be a good idea to get a fresh set in. Should probably change you wires also.
Old 07-21-2011, 07:04 PM   #18
Yoi should put dielectric grease on all electrical connections amd spark plug boots as well. Better current and helps alot for corrosion and wster shorting things out
Old 07-21-2011, 07:04 PM   #19
I'll put that on my to do list after I change the Spark (:
Old 07-26-2011, 01:30 PM   #20
Plugs were changed last Wednesday and the car has been running great ever since (:
Old 07-26-2011, 01:46 PM   #21
mrc
mrc's Avatar
Great! Glad to hear your back on the road.
Sequential turn signals mustangchassy Mustang Paint, Appearance & Detailing 16 08-07-2011 06:35 PM
Favorite Thing About Your Car Thread bradh2414 General Mustang Discussion 43 07-24-2011 04:55 PM
My car is hurt :( GoldenPonyBoy 2005-2010 V6 Mustang 25 07-19-2011 10:11 PM
Car Covers! Murdered_Stang General Mustang Discussion 8 06-26-2011 03:03 PM
09:30 AM
