Coil overs - Mustang Evolution
Old 07-21-2011, 05:41 PM   #1
silver98mustang's Avatar
Coil overs
I have a 1998 gt that has eibach pro- dampener struts. Upr has a coil over kit that includes everything except struts, would the struts I have work with the coil over style setup? Check my garage for the rest of the suspension mods to see if coil over would benefit my setup.
silver98mustang is offline   Reply With Quote
Old 07-21-2011, 07:06 PM   #2
onesickstang01's Avatar
Yes they will work. I did a coilover conversion on my fox body and it helped alot but that was also goin from drag springs to coilovers
onesickstang01 is offline   Reply With Quote
Old 07-23-2011, 09:33 PM   #3
I really like a stiff ride so what sort of spring rate should I go with I was recommended 250, but I was thinking more along the line of 350. What do you think
Old 07-24-2011, 06:44 AM   #4
Thats preference really. They will calculate a good spring rate for you depending on weight and other figures that they will ask you. Also if you are drag racing or street ect. They have different lengths as well so really tell them what you are looking for. You also need a steel caster camber plate. I would go with MM 4 bolt. I had the uprs before though and they help up alright as well
Old 07-24-2011, 09:06 AM   #5
I already have caster camber plates. Also, will I need to get an alignment? I plan on lower it mor than it already is.
Old 07-24-2011, 09:56 AM   #6
If you change the height then yes you will
Old 07-24-2011, 10:31 PM   #7
nickysixx's Avatar
Anything to do with height of a car your gunna need an alignment done.
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 07-24-2011, 11:02 PM   #8
Should I get rear coil overs at the same time or can I wait a while
Old 07-24-2011, 11:50 PM   #9
nickysixx's Avatar
Do all of them, saves u the time and Money on mount balance and alignment all at once.
Old 07-25-2011, 07:40 AM   #10
Re: Coil overs
the shock/strut has to be compatable and probably isnt, plus daily driver with coil overs can have issues/noises, rubbing etc many dont like it after they convert over.
Old 07-25-2011, 09:10 AM   #11
What do you mean by the shock/strut have to be compatible.
Old 07-25-2011, 07:02 PM   #12
The coil over tube has to fit aroud the outside of the shock/strut. I know kybs do and im pretty sure eibachs do as well. Bilsteins i believe have to be machined to fit which is why i dont have coilovers on this car. I did have a rubbing thump sound with my fox body coilovers when i hit hars bumps fast
Old 07-26-2011, 09:26 AM   #13
A day after I posted this thread, I saw upr at mustang week. They said they would fit over eibachs.
Coil packs blackdreams15 1996-2004 Mustang GT 8 07-27-2011 11:31 AM
02:08 PM
