Kenne bell question!! Need help - Mustang Evolution
Old 07-22-2011, 08:54 AM   #1
Ahmed ali khan's Avatar
Hello everyone i Am just planning to buy 2.1l kenne bell with 14psi of boost for my 04 mustang gt. Will buy mmr 900hp block too . The question is will kenne bell 2.1l will it scream loud with intake nd 14psi pulley?? I want power but sound too
I was planning to go with 2.6l kenne bell but have no dyno shops around or any kenne bell shops . I want full kit but want sound please give your feedbacks and help me.. Thanks
Ahmed ali khan is offline   Reply With Quote
Old 07-22-2011, 09:01 AM   #2
Re: Kenne bell question!! Need help
some KB's are not very loud at all, not sure which ones make tons of noise
Old 07-22-2011, 09:02 AM   #3
stampde's Avatar
the 2.1 is all you will ever need for a 2 valve motor , and Kenne Bell's are actually not to loud at all ,bit they do have a nice blower whine when u punch it
2011 GT Auto
Old 07-22-2011, 09:09 AM   #4
most KB's are not as loud as a stock Eaton though just FYI, I think the 2.0L screams
Old 07-22-2011, 09:13 AM   #5
Or anyone knows how is tork tech kit for 2v eaton m112? Is it good choice or kenne bell 2.1 @14psi
Old 07-22-2011, 09:32 AM   #6
drusmith's Avatar
Send a message via Yahoo to drusmith
KB 2.2 is LOUD as HELL!! trust me I know this first hand. My friend's my put a 2.1KB on her 99 GT and was very dissatisfied with the outcome. Might be different for your car but I believe she only got 8psi boost. She ran a 13.0 sec 1/4 mile. Her 2.1 is not that loud as SpectorV s=mentioned.
The 2.2 on my car puts out 20psi, but I have little different set up. LOL And it is loud!!! here are some sound clips:
‪'03 Terminator Cobra, Kenne Bell 2.2‬‏ - YouTube
‪2.2L Kenne Bell on a Cobra‬‏ - YouTube
good luck with your setup!! take plenty of pictures to share with everyone.
drusmith is offline   Reply With Quote
Old 07-22-2011, 09:35 AM   #7
drusmith's Avatar
‪03 cobra v.s 2.2 kenne bell gt crane/dustin‬‏ - YouTube
Here is a video of 03 GT with the 2.1KB
Old 07-22-2011, 01:08 PM   #8
stampde's Avatar
Originally Posted by drusmith View Post
Dru GT's don't respond like 4 valve motors , lol
but that should run a lot better than that , tune's not good or it needs a driver mod
2011 GT Auto
Old 07-22-2011, 01:26 PM   #9
drusmith's Avatar
Nice
Old 07-22-2011, 05:49 PM   #10
I don't think they make the 2.2l anymore I think that was a louder blower. I have the 2.1l and I'm only running 9 psi and I don't hear it much but I have a very loud exhaust. At 14 psi you should hear it more.
You will be happy with the torque. I make over 400 ft/lbs at 2000 rpm. My numbers were 405whp and 446 torque. Not bad for a 2V. It was tuned by Jon Lund.
The 2.1 wont get you to 900hp.
Also you will run out of fuel if you are going to use the stock pump with boost a pump. 9 psi will have you maxxed out at 6000rpm.
You will need a 03/04 cobra tank and fuel pump to run that boost level
ajpturbo is offline   Reply With Quote
Old 07-23-2011, 01:19 PM   #11
t0t4lbl4ck0ut's Avatar
They no longer make the 2.2. They only offer the 2.1 and 2.6. If your going to have a built motor then I will tell you exactly what the kenne bell tech guy told me. Basically he said with a built motor that the 2.1 will be extremely limited because you can only boost it to 14 psi. The 2.6 kit basically convert your gt to a cobra. It turn your intake and everything to the cobra but retaining the 2v. With a built motor your not going to get as much out of it as you expect with the 2.1 cause it's basically built for stock motors. The only thing you really need to worry about different with the 2.6 over the 2.1 is larger injectors cause it comes with none and a larger fuel pump and you have to have the cobra R hood for clearance reasons. That's it.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 07-23-2011, 01:20 PM   #12
Your in the same boat I am. I want a supercharger that will give tons of power and make alot of supercharger whine and Kenne bell will give you alot of both.
Old 07-23-2011, 05:38 PM   #13
Not true. You will not get supercharger whine with the 2.1.
Kenne bell says the 2.1 blower has a 750 hp rating so if you think that built for stock motors you have a hell of a stock motor.
And if you think you need the 2.6 to get you to cobra status that is wrong. I just turned 446 ft/lbs at the wheels with my 2.1 at 9 psi, a stock cobra can't do that. You would have to pulley a stock cobra to get there.
Also you can run more than 14psi with the 2.1 no problem if you have the supporting mods to handle that.
Old 07-23-2011, 06:12 PM   #14
That's not what I was saying. I'm not saying that's the only way to convert it. This is what the guy at kenne bell told me. Just relaying the message.
Old 07-23-2011, 06:13 PM   #15
And actually you can't run more then that without massive lose from the supercharger. It's not able to handle the massive air flow
Old 07-23-2011, 08:21 PM   #16
Sorry bro that's just not true. Not to knock Kenne bell but depending on which guy you spoke with you may have gotten some bad info. Google it, there are plenty of people running more than 14 psi with the 2.1
Efficiency may go down, but to say the motor is not able to handle the massive air flow is inaccurate.
Old 07-23-2011, 08:41 PM   #17
Well either way for less then 500 dollars you can get the 2.6 and get more performance from the get go. But only if your motor is built
Old 07-23-2011, 08:49 PM   #18
Horsepower per pound of boost may go down when boost goes over 14 psi but 20 still will yield more hp than 18psi
Old 07-24-2011, 06:48 AM   #19
onesickstang01's Avatar
You just have to be careful with heat. You need a very good heat exchanger to run high boost otherwise its dangerous for your motor. Heat in the intake cuts ignition timing which cuts power so if you are pushing too much boost and cant cool it then boost pressure is just a number and is being a negative effect past a certain point
onesickstang01 is offline   Reply With Quote
Old 07-24-2011, 10:31 AM   #20
Also, if you put too large of a blower on you may experience part throttle drivability issues. Bigger isn't always better
Old 07-26-2011, 08:36 AM   #21
Can i run 2.1 kenne bell at 14psi without heat issues? Will i need better heat exchanger or is kenne bell heat exchangers are fine with 14psi???
Old 07-28-2011, 06:56 AM   #22
drusmith's Avatar
Just talked to my buddy mom last night who has a KB 2.1.Se has no problems at all. she put down 370wrhp and ran a 12.5 1/4 mile.
Old 07-28-2011, 08:15 AM   #23
shaqfu's Avatar
moms + superchargers = hot
shaqfu is offline   Reply With Quote
Old 07-29-2011, 11:35 AM   #24
Wow that's really low horsepower. What's that have to do with what you quoted in your post? He was asking about 14 psi and the heat exchanger.
What did your buddy's mom have like 6 psi? I have a 9 psi pulley and turned 405whp.
Old 07-29-2011, 11:38 AM   #25
drusmith's Avatar
Sorry reading to many post together!
She has a 97 GT so that might be why! Not really close to what he has. Epic fail!
Old 08-11-2011, 11:08 AM   #26
I have last question its just that can i use my kn cai with kenne bell and increase boost on stock OEM KENNE BELL CHIP TUNE or will i have to get new tune
I am getting MMR COBRA BLOCK AND CAMS STAGE 2
Please help
Old 08-11-2011, 04:24 PM   #27
I've said it before and got in trouble in the forums but I'll say it again because it needs to be said.
I would quit messing around with some of the bad info that floats around here. Talk to kenne bell and they will tell you what is ideal for your setup and your goals. Also talk to your tuner and installer, it will save you money in the end. You are asking alot and kenne bell will tell you. I have a kenne bell kit and got tired of sifting through the wrong info that people who don't have kits and or can't afford them will try to tell you.
If you are doing cams as well the car will need to be tuned so why not get your tuners input?
1998 v6 exhaust question?? Gt.Vert Pre-2005 V6 Mustang 6 07-23-2011 12:29 AM
Cam install question mrc 1996-2004 Mustang GT 2 07-21-2011 11:24 AM
Question about LT Headers... illestdomer2005 2011-2014 V6 Mustang 4 07-18-2011 12:19 PM
nitrous question Black99Snake SVT Mustang 4 07-12-2011 09:42 AM
Aft cat deletion question Mustanglife Pre-2005 V6 Mustang 21 06-27-2011 09:30 AM
12:10 AM
