fuel rails - Mustang Evolution
Old 07-25-2011, 10:14 AM   #1
fuel rails
just wanderin im readin one my mustang mags amd alot ppl tlkin out upgrading feul rails can someone tell me the benifits of them if any?
Sb98gt is offline   Reply With Quote
Old 07-25-2011, 10:22 AM   #2
Titus Wadicus
svtlx's Avatar
Re: fuel rails
if your car is stock you dont need them. the larger rails just give the injectors a lil bit of reserve fuel so they dont empty out the rail, cause detonation and shatter a piston. but that's on 500hp motors or more typicaly, or stuff with big power adders like boost or nitrous where running lean for a split second can cause u big problems
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-25-2011, 11:05 AM   #3
oh ok thanks yea i am gonna run nitrous soon so i might look into it
Old 07-25-2011, 11:17 AM   #4
Titus Wadicus
svtlx's Avatar
Re: fuel rails
if your motor is stock... i still seriously dought u would need them unless u just want sum.
Old 07-25-2011, 11:34 AM   #5
well ive had a full motor rebuild with all new and forged bottom end then aldo a pi head swap and gonna run about 150 shot maybe
Old 07-25-2011, 11:48 AM   #6
Titus Wadicus
svtlx's Avatar
Re: fuel rails
sounds good bud... go for it
Old 07-25-2011, 12:33 PM   #7
oh ok thanks
BBK Vs. UPR fuel rails natm02 1996-2004 Mustang GT 9 08-07-2011 07:10 PM
Serious fuel smell Mustanglife Pre-2005 V6 Mustang 9 07-25-2011 03:18 PM
Fuel rails Z06 eater 1979-1995 Mustang GT 5 07-17-2011 09:43 PM
Fuel gauge issue macmarine39 1979-1995 Mustang GT 7 07-16-2011 05:19 PM
Fuel filter 04TRV6 1979-1995 Mustang GT 13 07-08-2011 03:21 PM
08:17 PM
