detionation? - Mustang Evolution
Old 07-31-2011, 11:45 PM   #1
detionation?
so i think my car is predetonating... it only does it around 4k rmps and stops after about 4300 if this i problem wats best way for me to fix it?
Sb98gt is offline   Reply With Quote
Old 08-01-2011, 08:25 AM   #2
Re: detionation?
is it tuned? are you running 87? try running 93 see if it gets better, or if you have a tune pull 2-4 deg of timing and see if it changes.
Pull the plugs and look at the ends to see if the ends are chipped or messed up (sign of detonation)
Old 08-01-2011, 08:41 AM   #3
yea its tuned but im runnin 93 and it only does it when i either dont put in octain boster or runnin low on gas
Old 08-01-2011, 09:17 AM   #4
Re: detionation?
if your tuner is unlocked (as in can do changes to the tune as you want) you can try to pull 2-4 deg timing out of it to see if that fixes it. You may need fuel in that RPM range. If its an SCT you can use livewire and data log it and send that to the tuner to review/update your tune with if they are decent and want to help that is.
I had to have more fuel added in my low rpm range where I got some detonation as an example.... took data logging to figure it out (data logging is easy review my article in the articles section on setting it up)
Old 08-01-2011, 09:23 AM   #5
ok yea i dont kno if tuner i git is unlocked bc tuner is not mine and i really dint wanna click tune car and mess up anythin i dont really kno anythin bout it
Old 08-01-2011, 09:24 AM   #6
Re: detionation?
give henson a call and he can go over some stuff with you, he is great to work with
Old 08-01-2011, 09:25 AM   #7
ok
Old 08-01-2011, 09:44 AM   #8
Re: detionation?
if you are not close to him there may be someone near you not sure where you are in Alabama
Old 08-01-2011, 09:47 AM   #9
south part near dothan and florida line
08:05 AM
