Engine Ticking..? - Mustang Evolution
Old 08-01-2011, 05:13 PM   #1
ColeJohnson's Avatar
Engine Ticking..?
I can hear a ticking sound in a certain rhythm coming from under the car. When we had it up on the lift it sounded like it was coming from the center of the engine where the tranny hooks up. From the engine bay it is very very faint and can only be heard when you pull the trottlebody to get about 1k rpm. I had my exhaust friend check the exhaust because I thought it was a leak but everything was nice and tight. When he took his stethoscope thing into the engine bay and put it down between the intake manifold and valve cover he said he could hear a ticking. But we don't know what it is.
Any ideas?
2016 Comp Orange GT (current)
Old 08-01-2011, 05:51 PM   #2
Region: Nevada
Clutch bearing ??
importkiller is offline   Reply With Quote
Old 08-01-2011, 05:58 PM   #3
nickysixx's Avatar
Is they're a leak anywhere? Like oil?
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 08-01-2011, 06:08 PM   #4
Re: Engine Ticking..?
No oil or any liquids of any sort leaking at all. And I have known for a while that the Pilot bearing and TOB have been on the fritz... Ya'll think it's that?
Old 08-01-2011, 06:33 PM   #5
bradh2414's Avatar
My dads truck has this. It's a bolt in the exhaust manifold that broke on his. Check those
bradh2414 is offline   Reply With Quote
Old 08-01-2011, 06:59 PM   #6
nickysixx's Avatar
It definitly could be one of the too. If the tob is seezing up could be it, is it sticky in any gear or decently hard to shift. I had to put a tob in my car because it seezed. Theyre was a knocking in my trans before hand too.
Old 08-01-2011, 07:12 PM   #7
No. The gears are really easy and the clutch is not troubled at all. It bites like new. Hm. I'll check out the manifold bolts! Can you see it without taking the plenum and throttle body off?
Old 08-01-2011, 07:52 PM   #8
nickysixx's Avatar
Take your intake off and you should be able to see
Old 08-01-2011, 09:11 PM   #9
What am I looking for exactly?
Old 08-01-2011, 09:29 PM   #10
nickysixx's Avatar
Depends on what bolt he's talking about, if he's talking about the center one everything needs come off, I have one in trunk if you want a picture of the one he's talking about.
Old 08-01-2011, 09:34 PM   #11
nickysixx's Avatar
This one is the one I would think that would cause a knocking out of the four but that wouldn't be in your trans area
Old 08-01-2011, 09:35 PM   #12
nickysixx's Avatar
It also wouldn't be felt in your clutch, it would be in the shifter. It would be extra tight to be put in gear.
Old 08-02-2011, 02:59 PM   #13
98gtdriver's Avatar
Lifters
-Eric
98gtdriver is offline   Reply With Quote
Old 08-02-2011, 07:57 PM   #14
Ok. it went away today so I went out normal driving.. On my way home from work I was accelerating normally and was about 45mph when klang(sounded like metal breaking/hitting)! Then it sounded like a blown header while I was driving. I limped my way back to my apartment(only a half mile drive from where it blew) and popped the hood. It was really loud and sounded like it was gushing air from the area around the throttle body/plenum. I looked for any visible damage and saw nothing. I took the CAI and throttle body off and still saw nothing out of the ordinary... The headers and exhaust are perfectly fine and tight. The clutch and the tranny still grip and shift fine although it has weird sounds coming from the tranny if you get under it and put your ear close to it while idling. Any ideas?
Oh, and there are still no liquids leaking.
---------- Post added at 08:57 PM ---------- Previous post was at 08:44 PM ----------
Actually.. I didn't check the headers themselves... That would make a lot of sense..
Old 08-02-2011, 08:01 PM   #15
sally2002's Avatar
If you are hearing it from the tranny I've heard of the torque converter doing what you are describing but I'm not for sure
sally2002 is offline   Reply With Quote
Old 08-02-2011, 08:22 PM   #16
98gtdriver's Avatar
It could be your egr valve.
-Eric
Old 08-02-2011, 08:40 PM   #17
nickysixx's Avatar
Very true, the way you just explained it sounding like a egr valve leak
Old 08-02-2011, 09:08 PM   #18
And how do we check this?
Old 08-02-2011, 09:39 PM   #19
nickysixx's Avatar
Attach everything and put your head next to the egr valve and see if they'res noise. Milk the butterfly while you do it. You'll hear either nothing or a clank/hiss.
Old 08-02-2011, 10:18 PM   #20
98gtdriver's Avatar
Its tjr circular knob looking thing on right side of pic. On the back side of it there are two tibes on flows in one flows out. Make sure bother are pushed all the way up. And look for and melting of the plug in that has a connection that goes ibto it. If there is any exposer of each individual wire that is connected to the connection if the sensor.
-Eric
Old 08-02-2011, 11:57 PM   #21
I took a video of it. I don't even know how to explain it. And the sound keep changing! It changed toward the end of the video after the second rev. I'm so lost, guys.
Old 08-03-2011, 12:16 AM   #22
98gtdriver's Avatar
Deff egr valve! One or both tubes are off the valve!
---------- Post added at 06:13 AM ---------- Previous post was at 06:13 AM ----------
It happened to my stang!
---------- Post added at 06:16 AM ---------- Previous post was at 06:13 AM ----------
Also if you dont get it fixed alot of bad things can happen. Trust me i found that out. You will have problems with your cats if you dobt grt it fixed asap
-Eric
Old 08-03-2011, 12:20 AM   #23
Las0mbra's Avatar
God that sounds bad...
Old 08-03-2011, 12:21 AM   #24
98gtdriver's Avatar
I know what yoy need its not to bad at all if yoy need anyhelp just let me know
-Eric
Old 08-03-2011, 12:32 AM   #25
I know it does!
Yeah man, lemme know what I need to get. Do you live in Baton Rouge? Nevermind, I just read that you're in Washington. Lol
Btw, I am running o/r pipes so no cats. Lol. But still I need it fixed now. I refuse to drive it until that god-awful sound is taken care of.
Old 08-03-2011, 12:33 AM   #26
98gtdriver's Avatar
All it is 3 conrctions two screws i believe. Vaccum line in and out plus sesor connection.
-Eric
Old 08-03-2011, 12:35 AM   #27
I need to get it replaced or just check the connections again?
Old 08-03-2011, 12:39 AM   #28
98gtdriver's Avatar
Go to your local part store and get a egr valve i forgot how much it is not to much tho. If you saw my picture there is a black looking knib. On the back side of it youll see a rectangular shaped black box with two vaccum lines. Thats the egr valve. Unplugg the connection along eith take off the vaccum lines. They are two differnt sizes so its hard to mix them up. It should be located next to the throttle body plenum
-Eric
Old 08-03-2011, 12:41 AM   #29
And those tiny lines are causing that big terrible sound?
Old 08-03-2011, 12:42 AM   #30
98gtdriver's Avatar
You cam check sonetime those line just blows off. So check it first
---------- Post added at 06:42 AM ---------- Previous post was at 06:41 AM ----------
It sounds like * put put put put put* right?
-Eric
Old 08-03-2011, 12:45 AM   #31
It sounds a lot like a tractor. Yeah, *put put put*
Old 08-03-2011, 12:51 AM   #32
98gtdriver's Avatar
Yess that most likely is that egr valve with the vaccum lines that popped ooff
---------- Post added at 06:51 AM ---------- Previous post was at 06:46 AM ----------
Sorry not the egr valve give me a sec to think of the name
-Eric
Old 08-03-2011, 12:55 AM   #33
98gtdriver's Avatar
Its the egr sensor looks like this
-Eric
Old 08-03-2011, 01:03 AM   #34
Ok. I just took that piece off and checked it... It's all great. And the lines were all securely attached and they all look new. And the air noise is actually coming from the passenger side, it seems.
Old 08-03-2011, 01:12 AM   #35
98gtdriver's Avatar
Huh i do not kbow it sounds like that senser
-Eric
'88 GT check engine light? robert81717 1979-1995 Mustang GT 7 07-12-2011 11:56 PM
Engine Swap BlackBeauty01 1996-2004 Mustang GT 5 07-07-2011 09:15 AM
Strange engine swap idea ArmyStang 1996-2004 Mustang GT 25 07-05-2011 10:29 AM
4.2L engine from a 98 3.8L bmabbott Pre-2005 V6 Mustang 11 07-01-2011 09:09 PM
08:42 AM
