Problem with OBD Code P0455 - Mustang Evolution
Old 08-06-2011, 10:28 AM   #1
Unhappy Problem with OBD Code P0455
My "service engine" light recently came on and the code given is P0455 which means I have an "evaporative system leak" somewhere between the canister and the engine. It is not the gas cap (incase you're wondering), but a leak somewhere in the line. A visual inspection showed nothing. I've read some posts posted by other people with the same problem (seems common on these Mustangs) Mine is a 2002 GT. However, no one have posted how they fixed the problem. I need a little help here. If any of you good'ol Mustang enthusiasts out there can help I really appreciate it.
Thanks.
tonyjuan is offline   Reply With Quote
Old 08-06-2011, 03:36 PM   #2
nickysixx's Avatar
Check lines for pin leaks or noises and make sure all clamps are snug. Had a similar issue was a unclamped house that expanded from heat allowing raw air in.
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 08-06-2011, 04:45 PM   #3
Re: Problem with OBD Code P0455
I'm gonna to a more thorough inspection on the hoses today. Thanks a lot.
Old 08-06-2011, 05:58 PM   #4
nickysixx's Avatar
No problem man
---------- Post added at 05:58 PM ---------- Previous post was at 05:25 PM ----------
If you have any questions just let me know, I've delt with so many evap issues
Old 08-06-2011, 06:02 PM   #5
Okay. I really appreciate that.
Old 08-06-2011, 06:06 PM   #6
nickysixx's Avatar
No problem, definitly let me know updates I'm on here every minute of the day trolling haha. I can definitly give you a few troubleshooting things
Old 08-23-2011, 08:38 PM   #7
I'm gonna really need more help here. I did what I feel was a good visual inspection of the lines, canister, lines coming from the filler cap, replaced the filler cap, and still nothing. I'm gonna need everything you got.
Thanks again man.
Old 08-24-2011, 06:25 AM   #8
onesickstang01's Avatar
Well if it was at my shop i would smoke it. I have a smoke producin machine that you hook up and it will show you the leak. On the 4.6 the only common leak i know of is the intake manifold gaskets. Also check up front at the egr area. There are several vac lines that are plastic and tend to break. Im sure you checked already
onesickstang01 is offline   Reply With Quote
Old 08-24-2011, 09:51 PM   #9
I will continue to inspect a little more closely. Maybe I should do it with the engine running.
Thanks much.
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
95 GTS code help and ideas....Please Txjason1 1979-1995 Mustang GT 9 07-01-2011 02:57 PM
03:40 PM
