Anti theft/ security problem - Mustang Evolution
Old 08-08-2011, 07:59 PM   #1
So I finished swapping everything over in my motor swap from 3.8 to 4.6 including dash harness, steering column, and BCM. Now when I try to fire up the car it cranks over but that's it. My theft light on the gauges flashes a lot as soon as I put the key in. So I'm guessing my anti theft is gonna have to be reset, is there any way I can do it myself or am I goin to have to bring it to the dealership?
zrider07 is offline   Reply With Quote
Old 08-08-2011, 08:09 PM   #2
Jamesgt08's Avatar
I think there is a fuse u can take out and get it started. Im not hundred percent sure but i think. My friend had a problem with his anti theft on his stang as well.
Jamesgt08 is offline   Reply With Quote
Old 08-08-2011, 08:38 PM   #3
Any idea what the fuse would be labeled as? It's anti theft, I didn't think it would be that easy! Lol
Old 08-08-2011, 08:41 PM   #4
Jamesgt08's Avatar
I have no idea what my friend did. I kno he messed with a fuse or wiring. Cuz his car would crank but not start. Ill ask him what he did.
Old 08-08-2011, 08:52 PM   #5
That'd be sweet! It's been really frustrating already!! I just wanna get it running.
Old 08-09-2011, 08:03 AM   #6
onesickstang01's Avatar
You have to have a dyno shop disable the PATS system. The only other thing you can do is try to use the original dash cluster. The cluster has to match the key. You can also switch the boards between the two clusters so that it matches. This is the v6 to v8 conversion car right?
onesickstang01 is offline   Reply With Quote
Old 08-09-2011, 09:38 AM   #7
Ya it's a conversion but I swapped all my wiring over from the v8 too. I just brought it to ford they'll reprogram it for me.
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 8 08-24-2011 09:51 PM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
anti theft device tazone99 1996-2004 Mustang GT 0 07-11-2011 12:25 PM
04:42 PM
