loud clicking noise - Mustang Evolution
Old 08-11-2011, 05:54 PM   #1
sally2002's Avatar
loud clicking noise
ok my car has developed a loud clicking noise and im not sure where its coming from. it sounds like its coming from the rear. i thought it was the brakes but i changed everything brake wise from front to back rotors to calipers and its still there. i am baffled. any help would be appreciated.
sally2002 is offline   Reply With Quote
Old 08-11-2011, 09:13 PM   #2
Blogger
99ford's Avatar
Re: loud clicking noise
Do you by chance have gears? ( A different rear axle than what came from the factory?) When Does it happen? during braking? all the time? Speed? How long has it been going on? etc... The more info you have the better.
Old 08-11-2011, 09:55 PM   #3
03GT88's Avatar
You could check for some debris trapped under your car.
03GT88 is offline   Reply With Quote
Old 08-11-2011, 10:19 PM   #4
I have the same issue. Jack the front end up and look at ur rubber swaybar bushings r yours falling apart to? If so poly bushings are like 12 bucks go get some swap it out should b ok from there allso look at ur rear ride control do u have a busted spring?
Hawk is offline   Reply With Quote
Old 08-12-2011, 05:20 AM   #5
sally2002's Avatar
It is all stock in the rearend. The only thing upgraded is my front steeda swaybar. It only happens when I brake. That's why I replaced all my brakes but it's still doing it. Someone said it might be a rearend strut but I'm not sure.
Old 08-12-2011, 07:14 AM   #6
get someone to drive the car and walk behind/beside it etc and try to track it down to a specific location
Old 08-12-2011, 09:53 AM   #7
If its ur susp or springs it should make the noise just by pushing down on the 4corners of the car 1 at a time when u hear it thats were its coming from . U said under braking does it ever do it under hard accel?
Old 08-12-2011, 07:13 PM   #8
Blogger
99ford's Avatar
^Yes good thinking! That's why we pay spec the big bucks just kidding.
I'm guessing a rear hub assembly. If its a tap/click sound during braking.
As someone else said try the 4 corners suspension test as well. The car should bounce up quickly and stop bouncing, with no noise. Report back and tell us.
Old 08-13-2011, 10:14 AM   #9
sally2002's Avatar
ok i took it to work today put her on the lift and shook the hell out of everything. i even took the cover off the rearend to see if there was something broke inside there. and still nothing so im thinking maybe i have a brake pad doing something funky cause it still is doing it. i even did the four corner trick and still nothing.
Old 08-13-2011, 02:24 PM   #10
onesickstang01's Avatar
Check the metal clips on the rear brakes. See if you are missing something. Look at E-brake cables. There is a little metal bracket that holds it it place. See if it is broken and rattling around. Also check if e-brake cable rubs on tire
onesickstang01 is offline   Reply With Quote
Old 08-14-2011, 01:52 PM   #11
sally2002's Avatar
ok i checked all the lines and looked for anythin that might be rubbing and still cant find anything. any other thoughts
Old 08-14-2011, 04:09 PM   #12
Check ur u joints and drive line as well as motor mounts and trans mounts just to see if anything is shifting around
Old 08-18-2011, 07:45 PM   #13
sally2002's Avatar
sorry guys that i am just getting back on. ok checked all linkages and they seem tight. checked all mounts and they are good no movement. checked both u joints and nothing broken. but its still doing it only when i brake and im getting frustratedi think im going to take the front calipers off to check them this weekend. any other ideas please shoot them this way thanks
Old 08-18-2011, 08:02 PM   #14
Dancobra75's Avatar
Can you please describe the noise again, where u think it's coming from and what conditions it presents itself(braking,acc.turning)
Dancobra75 is offline   Reply With Quote
Old 08-18-2011, 08:03 PM   #15
sally2002's Avatar
only braking and thats it
Old 08-18-2011, 08:10 PM   #16
Dancobra75's Avatar
I would say it's something with the pads, but after reading all the things you've done surely the replacement of the pads would have solved the problem, this may sound crazy but check inside your spare tire space, you wouldn't believe the customers that have brought me cars with rear noises that were just something banging around in the spare tire area lol, I'd like to hear it in person, hope you get it figured out, nothing worse than a noise you can't stop
Old 08-18-2011, 08:13 PM   #17
Are you positive there is nothing broken on your upper/lower control arms? It could be binding under braking, but I would imagine you would hear it over bumps as well.
Only other thing I can think of is as the previous poster said, possibly something just moving around in the trunk.
One more thought, check your exhaust assembly to be sure it's not rubbing against anything.
Old 08-18-2011, 09:03 PM   #18
Prolly a caliper clip then but if u sit in the car with it running and turn the stearing back and forth quickly if u hear it id say its ur r and p stearing box botls are lose if not it has to be ur breaks
2011 front end noise question. Help please drivinglesson 2011-2014 Mustang GT 15 08-31-2011 01:38 PM
Weird Clunking Noise CodyNelson 1996-2004 Mustang GT 5 08-18-2011 08:20 PM
sqeaky noise 98blckbeauty 1996-2004 Mustang GT 7 08-12-2011 08:48 PM
Noise going into gears bradh2414 Pre-2005 V6 Mustang 5 07-20-2011 03:46 AM
screeching noise vinnygt 1996-2004 Mustang GT 27 07-08-2011 10:14 AM
07:45 AM
