Musatng Hesitation - Mustang Evolution
Old 08-13-2011, 10:09 PM   #1
dbroncolish's Avatar
Region: Nevada
Musatng Hesitation
I have a 02 Mustang GT ,133k. I have a hesitation problem where it feels like something is stifling the engine, loss of power etc.. it doesnt do it when the engine is cold. Once the engine warms up just a little the problem starts. I had a problem with a vacuum hose by the throttle body but fixed that, the spark plugs only have 20000 miles on them , the fuel filer was replaced couple months ago, and NO check engine light is on, i have cleaned the MAF sensor, the PVC sensor is still good i dont know what it can be because there is no check engine light that is on. Any suggestions?
dbroncolish is offline   Reply With Quote
Old 08-13-2011, 10:11 PM   #2
dlove03mach1's Avatar
Region: Arkansas
Fuel injection problem maybe...
dlove03mach1 is offline   Reply With Quote
Old 08-13-2011, 10:14 PM   #3
Region: Nevada
Re: Musatng Hesitation
Like dirty injector? Im going to check the fuel pressure and vacuum pressure tomorrow
Old 08-14-2011, 01:04 AM   #4
ColeJohnson's Avatar
I've been having that problem too. Like a tiny shuttering when accelerating where the engine kinda produces a little less power than usual for a split second. Let me know what you find out! I cleaned my TPS and MAF as well.. All my vacuum lines are fine.
2016 Comp Orange GT (current)
Old 08-14-2011, 11:06 AM   #5
mhobbs's Avatar
I have a 96 gt i had that problem and cleaned my maf sensor and it solved it.
mhobbs is offline   Reply With Quote
Old 08-14-2011, 11:08 AM   #6
nickysixx's Avatar
I have the same problem it's literally for a half a second when my cars warm usaully when I'm doing 50 mph +
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 08-14-2011, 11:08 AM   #7
mhobbs's Avatar
also with that many miles you might want to take apart your throttle body and clean it. i had a ton of just sludge type build up that i cleaned at the sme time i cleaned my maf sensor
Old 08-14-2011, 11:14 AM   #8
nickysixx's Avatar
Spark plugs and wires have only 600 maybe less on them. Clean my Maf, my throttle body, and my butterfly.
---------- Post added at 10:14 AM ---------- Previous post was at 10:14 AM ----------
Also redid all my vacuum lines. I know it's not an issue with any of that.
Old 08-15-2011, 05:28 PM   #9
Region: Nevada
maybe EGR ?
Old 08-15-2011, 08:25 PM   #10
blackdreams15's Avatar
I definately need 2 kno because i'' having the same problem as we speak i have an 02 with about 135k on it and its very annoying! I think im going to try coil packs!
blackdreams15 is offline   Reply With Quote
Old 08-16-2011, 03:20 AM   #11
nickysixx's Avatar
Coil packs hold power and distribute it if I'm thinking correctly. I'm also half asleep. I'll correct myself in the morning. I think it's my egr valve and fuel injectors
Old 08-16-2011, 07:33 AM   #12
mrc
mrc's Avatar
Have your intake manifold checked out. That is one of the main symptoms when it first starts to crack somewhere. Car will run for the first minute or two untill it starts to warm up and then it starts to hesitate like it has a small vacuum leak. Once it has been doing that for a little while you usually will start noticing your coolant level dropping. If you have already spent money replacing parts i would recommend checking out the intake manifold before throwing more money at the problem.
PI intake manifold swap,Stack racing CAI, Lawson Incinerator mufflers, SCT tuner.
mrc is offline   Reply With Quote
Old 08-16-2011, 10:29 AM   #13
Any other suggestions past that? I had my intake manifold replaced a few months back when it started it had 2 cracks in it! My uncle is a mechanic and we have covered almost everything possible! Now it just comes and goes!
Old 08-16-2011, 12:13 PM   #14
nickysixx's Avatar
Nah, only 800 miles on my intake manifold
Old 08-17-2011, 10:45 AM   #15
Region: Nevada
my intake is new as well
Old 08-25-2011, 05:46 PM   #16
Region: Nevada
Cleaned the MAF cleaned the throttle body, put a new fuel filter on, ran a fuel pressure test and that was fine, put in a new EGR valve in and the car still has the problem
---------- Post added at 03:46 PM ---------- Previous post was at 03:28 PM ----------
Did the coil packs
Work?
Old 09-17-2011, 08:06 PM   #17
Region: Nevada
check engine light finally came on and misfire in cylinder 8 replace the coil again and fixed the problem ! that coil only lasted lasted 6 months hopefully theirs not some kind of a problem in cylinder 8, but at least it is fixed and finally drives great again
Old 09-18-2011, 07:44 PM   #18
Kycapsfan's Avatar
Ok I came here to see if anyone else is having a problem similar to mine. And here we are.......I have an '02 with misfire on #8 too. Replaced coil pack and injector and problem remained. Compression test revealed all cylinders were at 195-200, except for #8 having only 145-150. Engine has 100,000miles and uses no oil or water. It has a slight miss till around 2500rpms and seems to clear up. All I know is run it till she blows and perhaps during the autopsy we'll find the problem or not. ?????
Kycapsfan is offline   Reply With Quote
Old 09-18-2011, 09:38 PM   #19
Las0mbra's Avatar
Make a new thread. You'll get this post deleted for hijacking his thread.
Old 09-18-2011, 09:45 PM   #20
Kycapsfan's Avatar
Oh I'm sorry didn't really mean to hijack. Just added my similar situation and what I'd tried and found out. I apologize if I did.
Old 09-18-2011, 09:53 PM   #21
Las0mbra's Avatar
Oh, nah, it's fine... And btw, nice stang! Make a introduction post and you can add some pics and your problem on there.
Old 09-18-2011, 11:20 PM   #22
jjsg09's Avatar
How is his post considered hijacking? Its a related topic.
Old 09-19-2011, 10:34 AM   #23
Region: Nevada
idk i noticed before when i changed my spark plugs all of them looked fine except cylinder 8 it was pretty wet with oil hopefully it doesn't turn into a problem
Old 09-19-2011, 10:47 AM   #24
jjsg09's Avatar
That sounds like your piston rings are shot aka blow by, you shouldn't have oil on your plugs.
08:26 PM
