transmission issue.... - Mustang Evolution
Old 08-19-2011, 03:36 PM   #1
mhobbs's Avatar
Angry transmission issue....
yesterday i got on to the hwy and got on the gas pretty hard just enough to make a chirp the transmission made a not very good sound..almost like a belt slipping type of sound. now it wont shift outta first unrill 3k rpm?..its 96 gt automatic i havnt taken it to a shop yet. anybody got an idea of whats wrong?
mhobbs is offline   Reply With Quote
Old 08-19-2011, 10:54 PM   #2
Lastoria24's Avatar
Send a message via Skype™ to Lastoria24
Could be anything really, hard to say...
First thing I'd do is check the fluid. Suprisingly enough, that can give you the information you need...
Lastoria24 is offline   Reply With Quote
Old 08-19-2011, 11:10 PM   #3
Otlaw80's Avatar
Re: transmission issue....
I had a similar problem with my 95 gt/auto. If you got on it hard enough to start breaking the tires loose, the 1-2 shift accumulator spring was broken and would shift sideways just a little and get stuck causing it to not shift into 2nd until the rpm's got high. Actually a simple fix. Just have to drop the pan and you can see the accumulator. Take out a snap ring and give it a tap to straighten in out, so it will slide out. Then you can replace the spring. Ford part only, they should still be able to get it for you. Was right around $50 for the whole thing. Piston,springs, etc. Maybe its the same thing?? Would be worth a shot if your able to check it yourself.
Old 08-19-2011, 11:24 PM   #4
Otlaw80's Avatar
Here is what it looked like when i dropped my pan in the 1st picture. You can see its twisted sideways a little. The 2nd picture is what is in there (or at least supposed to be)
Radio shaker issue Katylascu 2005-2010 Mustang GT 6 08-31-2011 05:17 AM
Transmission problem carlgator 1979-1995 Mustang GT 1 08-14-2011 09:52 PM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
Transmission issue goherd 2005-2010 V6 Mustang 2 07-22-2011 06:18 PM
Overheating issue Edge4 1979-1995 Mustang GT 11 07-19-2011 09:06 PM
03:47 PM
