I have a leaking issue... :( - Mustang Evolution
Old 08-20-2011, 12:04 AM   #1
98StangKid's Avatar
So, today after thinking that my top radiator hose was loose and just losing a little bit of fluid... Turns out, my radiator is cracked... So I ordered a new one today, but it said something about having to get under the car and installing it from the bottom... I would much rather go from the top, and it didn't look like it would be that bad. But Idk... Has anybody fooled with this before? Any help for a rookie??
Thanks again everyone!
'01 Cobra
Forged Internals, Limited Slip Differential, 3:73s, Bama Tune, Pro 5.0 Short Shifter, Mach 1 Air Intake, 31 Spline Moser Axles.
98StangKid is offline   Reply With Quote
Old 08-20-2011, 08:26 AM   #2
mrc
mrc's Avatar
Changing the radiator is super easy. You do it from the top. Its a bit easier to loosen the oil and transmission cooler lines from the bottom but you can do it from the top. You will probably have to take off the bottom coolant line from the bottom. I would recommend getting new coolant hoses and clamps well you're at it. The fan and radiator all come off as one piece and then you put the fan on the new radiator before installing it. It shouldn't take you more then an hour or so to do the whole job. Make sure the coolant cock is tight before putting in new coolant.
PI intake manifold swap,Stack racing CAI, Lawson Incinerator mufflers, SCT tuner.
mrc is offline   Reply With Quote
Old 08-20-2011, 09:37 AM   #3
wereKEV's Avatar
Re: I have a leaking issue... :(
+1
wereKEV is offline   Reply With Quote
Old 08-21-2011, 12:17 PM   #4
bobsurvives's Avatar
What radiator did you buy? Whats the brand?
bobsurvives is offline   Reply With Quote
Old 08-21-2011, 12:19 PM   #5
iwannagofast's Avatar
Leaking? i guess you should have thought twice before hit that chick raw dog.
iwannagofast is offline   Reply With Quote
Radio shaker issue Katylascu 2005-2010 Mustang GT 6 08-31-2011 05:17 AM
transmission issue.... mhobbs 1996-2004 Mustang GT 3 08-19-2011 11:24 PM
Transmission issue goherd 2005-2010 V6 Mustang 2 07-22-2011 06:18 PM
Overheating issue Edge4 1979-1995 Mustang GT 11 07-19-2011 09:06 PM
Fuel gauge issue macmarine39 1979-1995 Mustang GT 7 07-16-2011 05:19 PM
06:24 PM
