Motor acts like traction control is active - Mustang Evolution
Old 09-20-2007, 07:07 PM   #1
ArmyStangGT's Avatar
Question Motor acts like traction control is active
Need help guys how do you reset the traction control to stop the cylinder cut out? Wife washed the car today and cleaned under the hood and now when I started it the traction control light was on on the button. I read the book and it says that it needs to be serviced my guess is that there is a fault in the system can I disconnect the battery adn then reconect it after an hour to clear this or does it have to go to a dealer to be reset?
Help me out here my baby is running like crap!!!!!!!!!!
Gary
'01 GT
MagnaFlow Exhaust
K&N Air Filter
Going on blocks next year. :)
ArmyStangGT is offline   Reply With Quote
Old 09-20-2007, 07:27 PM   #2
Re: Motor acts like traction control is active
OK fixed now. Took the NEG lead off the battery for 5 min. then hooked back up and started the car and drove fine. Everything is back to normal and the wife is feeling better now.
'01 GT
MagnaFlow Exhaust
K&N Air Filter
Old 09-20-2007, 09:26 PM   #3
It's definitely a good idea to do that first...can't ever hurt.
Old 09-21-2007, 12:55 PM   #4
KrazyPony's Avatar
so basically it needed a reboot!
http://i201.photobucket.com/albums/aa307/KrazyPony/KrazyPonysigBlue.jpg
KrazyPony is offline   Reply With Quote
Old 09-21-2007, 06:10 PM   #5
Thomas91169's Avatar
did you get any water under the hood? if you did, could be the spark plugs grounding out (water down in the plug galley).
if its a real issue, it will come back once the ECU runs for a couple miles or so. sounds like it went into limp mode if its not a issue thats a result of your underhood extravaganza.
-Thomas-
Old 09-22-2007, 06:34 AM   #6
Its been two days and still running great. Guess just needed a reboot so she is fine.
Thomas, while idling i unpluged the coil to each plug one at a time and you could tell the difference so was not a plug was the TC system.
'01 GT
MagnaFlow Exhaust
K&N Air Filter
Old 09-29-2007, 10:42 PM   #7
Send a message via AIM to Drewskie
no offense to your wife but that is why i NEVER let my girlfriend touch my car lol
Drewskie is offline   Reply With Quote
Burn out-traction control? occhopperman27 1996-2004 Mustang GT 19 08-21-2009 02:19 PM
Traction control? braumab General Mustang Discussion 30 12-21-2007 01:50 PM
ABS and Traction control light on rugman1969 1996-2004 Mustang GT 1 09-30-2006 03:09 PM
Traction Control Q wrecked2001 Pre-2005 V6 Mustang 12 03-20-2006 05:57 PM
traction control greenpony02 Pre-2005 V6 Mustang 28 05-02-2005 09:57 PM
05:51 PM
