Best Way To Get 500 Horses For $4,000 - Mustang Evolution
Old 08-21-2011, 06:57 AM   #1
504 Stang Rida's Avatar
I Have An 02 Mustang Gt Stick Shift & Need To Know The Best Parts From Gears, Coils, Pulleys, Plugs, Heads, Headers, Clutch And More To Get Me To 500 Horses On A Stock Gt Block...$4,000 Is My Limit For Now...All My Friends Have Turbo Charged Imports & I'm Trying To **** On Them & Show Them Some American Muscle
504 Stang Rida is offline   Reply With Quote
Old 08-21-2011, 06:59 AM   #2
Jamesgt08's Avatar
Get a turbo.
Jamesgt08 is offline   Reply With Quote
Old 08-21-2011, 07:02 AM   #3
Originally Posted by Jamesgt08
Get a turbo.
I was thinking about that but I want to upgrade my engine before I add a supercharger or turbo
Old 08-21-2011, 07:16 AM   #4
stampde's Avatar
Re: Best Way To Get 500 Horses For $4,000
buy a stroker engine from DSS Racing for about $3500 and throw a 125 shot of NO2 ON IT
500 horse is tough to reach on a budget a good strong 331 or 347 stroker with a good set of heads and cam will get you in the 400 - 425 range and still be street able ,anything higher than that on just motor will be high compression ( wont run for crap on pump gas ) and very big head and cam , not good on the street ......
2011 GT Auto
Old 08-21-2011, 07:23 AM   #5
I have a friend that has an 04 Gt and he makes 731 at the rear wheel off his stock block but he residents his heads, cams, plus he has a whipple supercharger but he also dropped like $9,000 on his engine...plus my engine only has 17,000 on it so I would like to use it
---------- Post added at 08:23 AM ---------- Previous post was at 08:22 AM ----------
Originally Posted by 504 Stang Rida
I have a friend that has an 04 Gt and he makes 731 at the rear wheel off his stock block but he redid his heads, cams, plus he has a whipple supercharger but he also dropped like $9,000 on his engine...plus my engine only has 17,000 on it so I would like to use it
Old 08-21-2011, 07:26 AM   #6
stampde's Avatar
WELL SINCE THE BOTTOM end is fresh , put a good set of heads ( AFR's , Edelbrock , Dart etc ..) a good cam, headers ,intake and a shot of Nitrious ....
2011 GT Auto
Old 08-21-2011, 07:28 AM   #7
Yea that's wat I was thinking...my grandpa owns his own shops so getting everything installed is free for me...I'm just looking for the best parts
Old 08-21-2011, 08:27 AM   #8
iwannagofast's Avatar
Forced induction is really the only way to get those numbers off that amount of money
iwannagofast is offline   Reply With Quote
Old 08-21-2011, 08:12 PM   #9
t0t4lbl4ck0ut's Avatar
Yea really that Is the only way. Nitrous will give you instant cheap power but its a different story when your not on nitrous. Mm&ff did a 4.6 2v and put a set of 5.0 heads on it. Theres only one company that makes them and Im not sure who it is but they ended up forging the internals, heads, cams and before their nitrous it made about 500 and after over 600 but that's way more then 4k
t0t4lbl4ck0ut is offline   Reply With Quote
Old 08-21-2011, 08:55 PM   #10
Pistons, rods, and a sh*t ton of nos lol
DrSalt22 is offline   Reply With Quote
Old 08-21-2011, 09:03 PM   #11
I'd only run nitrous if your looking at strip power and thats it. If your looking at constant power I wouldn't get it.
Old 08-21-2011, 09:11 PM   #12
Why would u put 5.0 heads on a 4.6?! highly doubt they would fit #1 and #2 4.6 already have a good market for performance head so why would they do that?
Old 08-21-2011, 09:22 PM   #13
They aren't just a standard 302 head. They are designed for the 4.6. And it was in mm&ff, So the kit does exist.
---------- Post added at 03:22 AM ---------- Previous post was at 03:15 AM ----------
I'm not exactly sure who make them cause I have an issue that they talk about that project in terms of doing more to the 2v motor as far as forced induction. They had 2 4.6 2v motor and one was cammed, new heads, upgraded intake and it made 399 engine hp. The other motor had the 5.0 heads, cammed and was built and made 500 engine. Then they slapped a kb on the 399 hp motor and forged the internals and it made over 700 with 20 psi
Old 08-21-2011, 10:47 PM   #14
So from my understanding, those heads flow better then anything in the 2v 4.6 market?
Old 08-21-2011, 10:57 PM   #15
I'm guessing so. I don't know the complete details on them nor could i find them online but that's a blind search not knowing what I was looking for. Just looking at it, it was a dedicated 5.0 stroker 2v, with the 5.0 heads, elevated cam lobes (didn't say specifically what brand or duration), and trick flow intake. I don't know if it's just a company that sells milled heads or what but they don't go into any more depth then the industries only 5.0L heads.
Old 08-21-2011, 11:11 PM   #16
Im sorry but you are wrong there is no logical explaination why anyone would put 5.0 heads on a 4.6! the 4.6 is a SOHC the 5.0 was a pushrod motor, so it aint gonna work!
Old 08-21-2011, 11:15 PM   #17
Naw American Muscle has it on there website and so does Rpm Out let its the 5.0 head built for the 4.6 block...all the reviews say it has the best compression out of all the heads and produces the most power
Old 08-21-2011, 11:51 PM   #18
Lol I was gonna say it's in mm&ff I'm not making it up lol
Old 08-22-2011, 04:26 AM   #19
Yea they say the 5.0 heads for the 4.6 block if built right can produce over 600 horses safely just the engine alone but tha wit stage 3 products
Old 08-22-2011, 09:51 AM   #20
Post the link to these heads because i still cant find them
Old 08-22-2011, 02:13 PM   #21
500 at the flywheel or 500 at the rear wheels? If 500 at the flywheel a supercharger/turbo setup will do it but it will cost more than 4k unless its used... and even then probably more than 4k and you will be at the limit of that car without a built motor
if 500 at the rear wheels, you wont get there with out a power adder/built motor
Old 08-22-2011, 08:23 PM   #22
Go to www.americanmuscle.com and look under engine parts for the 99-04 Mustangs
---------- Post added at 09:23 PM ---------- Previous post was at 09:20 PM ----------
I'm looking for 500 at the engine...the engine I have now is in dam good shape it only have 17,000 miles on it and I have a month on this projext...the engine is out of the car so I'll be gettin it rebuilt
Old 08-22-2011, 08:35 PM   #23
Ok i see the patriots and the trickflow heads, neither were ment for a 5.0
Old 08-22-2011, 08:46 PM   #24
Sell ur 4.6 and combine ur money to build a 427 windsor thers over 500 fwhp when u want to throw a blower on top swap out ur cam pistons and injectors
Hawk is offline   Reply With Quote
Old 08-22-2011, 09:11 PM   #25
Here it is
http://www.americanmuscle.com/frpp-m...oss-block.html
Old 08-22-2011, 11:31 PM   #26
so ur gettin a bored out 4.6 mod motor, ya still cant put 5.0 heads on it. Its a mod motor which will only accept mod motor heads
Old 08-22-2011, 11:37 PM   #27
Lol I was gonna say that's not heads but still not a bad deal. It's not just a bored 4.6 because you can't bored a 4.6 with stock stroke to a 5.0 and have a structurally sound block. The materials just aren't there
Old 08-23-2011, 10:50 AM   #28
I gotcha now, the way it was worded before really threw me off
Old 08-23-2011, 11:22 AM   #29
It's all good. Were all here for the same reason. MUSTANGS. That's why we have friendly arguments and nobody really gets mad or what not
Old 08-23-2011, 02:38 PM   #30
If only that were true some people get real mad. The only problem with the 5.0 block is that you will have to also have to buy pistons. So with the block, pistons, heads, cam and the cost of the miscellaneous parts odds are you will be over $4,000
Old 08-23-2011, 04:23 PM   #31
That block reuses everything but your pistons but performance wise you will need all that stuff to get anywhere
Old 08-24-2011, 03:27 PM   #32
I've looked at the rating of an '01 Pi motor going in my '98 mustang Gt. 500hp on stock internals is Max but I would not recommend to push it that far. As of now with the add on I have. I'm looking at 450-475 HP. With torque in 400-480 range . That is no super charger or no Turbo. Its all motor
soldierdude28 is offline   Reply With Quote
Old 08-24-2011, 08:45 PM   #33
CodyNelson's Avatar
Region: West Virgina
How do you plan on getting those numbers NA?? With the exception of nitrous I do believe that is out of reach. With full bolt ons, heads, and cams and a tune you are lookin at like 355 at the wheels at the very max from what I've seen
Old 08-24-2011, 09:57 PM   #34
Im going to agree^^
Old 08-24-2011, 10:07 PM   #35
I'm tellin ya you can get over 400 rwhp from a na engine. But you have to up the compression and it's gonna cost ya over 4k to do it
Letting the horses run wild Tyoung68 Classic Mustangs 2 08-13-2011 05:29 AM
Instructions for adding a sub to the Shaker 500 Evilcartman Mustang Audio & Video 3 08-03-2011 11:36 PM
Shaker 500 CD changer problem pony_dogg Mustang Audio & Video 1 07-18-2011 05:26 PM
02:24 PM
