H & R springs!!! - Mustang Evolution
Old 08-23-2011, 03:09 PM   #1
secomejia's Avatar
H & R springs!!!
Hey everyone i just put the rims on my pony, but now i want get that gap out of the way!!!!! Should i go with h&r????? Let me know what u guys think??????
ID:	30849   Click image for larger version
secomejia is offline   Reply With Quote
Old 08-23-2011, 03:15 PM   #2
Greg687's Avatar
Region: New Mexico
Re: H & R springs!!!
Some gaps are good... just saying
Never heard of h&r. How are their prices?
Greg687 is offline   Reply With Quote
Old 08-23-2011, 03:33 PM   #3
secomejia's Avatar
The springs are like 240. U think it looks nice the way it is or should i lower it!!!
Old 08-23-2011, 04:15 PM   #4
ColeJohnson's Avatar
I'll be getting H&R super sports on my GT soon. I highly recommend them! We lowered my buddy's 2004 Mach 1 and it's stance is sick now.
But if you lower it with the super sports then don't forget the camber caster plates and bumpsteer kit. And might wanna upgrade shock/struts if they're higher miles. And ball joints.. Yeah the springs are only $240 but I could probably spend $1200 on lowering my car the right way. Lol
2016 Comp Orange GT (current)
Old 08-23-2011, 04:19 PM   #5
secomejia's Avatar
My car only has 32k miles, why do i need the ball joints and the bumpsteer kit???
Old 08-23-2011, 04:29 PM   #6
t0t4lbl4ck0ut's Avatar
FYI if you have 315 for rears do not lower your car to the extreme cause you will carve up you tires
---------- Post added at 10:29 PM ---------- Previous post was at 10:26 PM ----------
I just put a set of h&r race springs on for that reason. And when you do you springs you gotta do your shocks too. You will do major wear on your springs if you don't support them properly with a good set of shocks.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 08-23-2011, 07:41 PM   #7
H&R Super Sports will drop the car ~1.6" in the front and ~1.75" in the rear. Race Springs drop the car less, ~1.25.
I have th SS's, and I love them...amazing stance and the car does feel more composed on the curves. My drop is slightly lower than usual as I took out the isolators...this will make the ride more harsh and louder in the cabin, but that's what music's for, lol.
If you get the SS's, plan on new shocks/struts and CC plates at the minimum.
At 32k miles, your stock parts will last for a little while but will eventually wear due to the changed load and rate given off by the progressive springs.
New ball joints aren't a bad addition and a bumpsteer is a must. It will be greatly exaggerated after lowering and can cause uneven tire wear and an unpredictable car on the road over bumps if not countered.
The CC plates, bumpsteer kit and solid alignment will get your car's geometry back into spec to prevent uneven tire wear and possible blowouts, even with 315's on the back
It is important to to suspension the right way. Just installing lowering springs will only bring wear issues in the future. It's best to spend the extra cash and replace the necessary components at the same time.
You will spend more in the short term, but you and your car will appreciate it in the long run
Old 08-24-2011, 06:33 AM   #8
onesickstang01's Avatar
Like a couple guys said above lowering is not cheap to do right. Springs are not the only thing you need to do. You want to do springs, shocks and struts, bump steer, CC plates, and many times ball joints (steeda x2 makes a great setup for lowered cars that really helps)
onesickstang01 is offline   Reply With Quote
Old 08-24-2011, 07:00 AM   #9
03GT88's Avatar
I have steeda sport springs. I'd reccomend progressive rate springs
03GT88 is offline   Reply With Quote
Old 08-24-2011, 11:36 AM   #10
Greg687's Avatar
Region: New Mexico
I agree that lowering it would look better. It's on my list for my Mustang. The "gap" I was talking about is another kind all together
Old 08-26-2011, 08:09 AM   #11
CrimsonGT's Avatar
I have Eibach pro lowering springs and Eibach pro shocks and struts And i love my setup i have not done the cc plates or bumpsteer yet but they are planned for in the future. My only regret is not knowing Eibach made a coilover system for my Stang but if I had it all to do again I believe I would look into the Eibach coilovers just so I could have a little more adjustment options to perfect my stance. Eibach is expensive but top of the line IMHO I'll never forget putting 6 carlengths between me and a new ss camero in the corners after the install ..... He owned me in the straight but he couldn't hang in the corners I was so proud
CrimsonGT is offline   Reply With Quote
lowering springs secomejia 1996-2004 Mustang GT 2 08-15-2011 10:51 AM
Ebach springs.. Brandon91 1979-1995 Mustang GT 3 08-05-2011 06:38 PM
Lowering springs. GoldenPonyBoy 2005-2010 V6 Mustang 13 07-26-2011 06:40 PM
Lowering springs for 2007 Redmustang2007 2005-2010 V6 Mustang 10 07-14-2011 03:28 PM
Post pic of your car with springs gtstyles2 2011-2014 Mustang GT 25 07-11-2011 06:54 AM
08:48 AM
