Subframe connectors - Mustang Evolution
Old 08-24-2011, 01:35 AM   #1
Subframe connectors
So I have a 95 mustang that I just put a 4.6 into and it feels really wavy if that's the right word mostly when I'm going through dips and bumps. Also when I'm accelerating. So I'm hoping subframe connectors will help me. The thing is I don't really want to put anymore money into the car right now and I'm quite sure I could build something to weld in there. Does anyone have some good, quality pics of the connectors installed or even uninstalled but a good close-up of the ends? Any help would be great!
zrider07 is offline   Reply With Quote
Old 08-24-2011, 04:28 AM   #2
ksrumbel's Avatar
I don't know if the subframe is your problem. Sounds like struts to me
ksrumbel is offline   Reply With Quote
Old 08-24-2011, 07:18 AM   #3
onesickstang01's Avatar
Since the car was originally a v6 it has softer springs and because of the heavier v8 it tends to do that. You can swap the v8 springs over or buy lowering springs ect. I would also bet that the struts are done as well. Subframe connectors are always helpful but wont help the floating feelin you are explaining. I wouldnt bother making them though because you will have to bend metal and the metal you use wont be nearly as strong as something like Maximum motorsports connectors
onesickstang01 is offline   Reply With Quote
Old 08-24-2011, 09:57 AM   #4
Ok that would explain it! I was gonna throw the other springs in when i did the diff but the one was broken right on the end. Guess it's maybe time for a lowering kit
Subframe connectors zrider07 1996-2004 Mustang GT 8 07-20-2011 04:21 PM
Subframe connectors zrider07 General Mustang Discussion 0 07-20-2011 12:46 PM
05:06 AM
