Suspension advice - Mustang Evolution
Old 08-26-2011, 03:51 AM   #1
Suspension advice
O I'm looking at getting a different setup for my 96GT. I'm not sure if I actually want to lower it or leave it stock height but just with different springs. Anybody have advice on what I should do? I'm not looking for any extreme kit and I dint really wanna spend a ton of money either.
zrider07 is offline   Reply With Quote
Old 08-26-2011, 04:59 PM   #2
kickerofdoom's Avatar
Ford racing spring
Old 09-07-2011, 05:22 AM   #3
DaBluedude's Avatar
Re: Suspension advice
How much is not too much? I did a full eibach pro kit (springs and shocks and struts) and it did my stang wonders. lowered it just about an inch (CC plates needed for alignment). The car grips way harder and i had to buy a set of corbeau seats (which i also recomend to anyone with the dreaded broken seat bracket issue...) to hold me in the damn car ! haha. Also did the rear control arms HUGE difference... total night and day. also replaced as many bushings as i could...
suspension parts totaled about 1300$ (with the control arms) seats were 1100$ had to get a shop to install the rear control arms (and springs) because i had to get the bushings burnt out 219$ and an alignment.
It was WELL worth it to do it all. And matching your springs with shocks/struts designed for them doesnt hurt...
Old 09-07-2011, 08:12 AM   #4
Tib
Tib's Avatar
Mine has the roush stage 2 kit on it which is a full suspesion...I recommend it. You'll just have to decide how low you want to go, the lower you go typically the tighter the suspension and the more bounce you will feel. Although when done properly makes a incredible handling car.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 09-07-2011, 08:19 AM   #5
those cars sit so high stock its sad really. the best handling will be around when the A Arm is even with the ground, now its pushed down. I believe its around 1-1.25 inches~
If this is a daily driver stiffer springs may get old quick, also with the year of your car you probably need new shocks/struts.
suspension is finally installed! tigercrazy718 2005-2010 Mustang GT 8 08-19-2011 12:09 AM
Advice 89white GT General Car Discussion 11 08-17-2011 04:38 PM
Rear end advice t0t4lbl4ck0ut 1996-2004 Mustang GT 6 08-07-2011 07:59 PM
Suspension? Carlos92 Pre-2005 V6 Mustang 16 07-29-2011 08:29 AM
2011 5.0 suspension question - roush trak pak fitment apex32 2011-2014 Mustang GT 1 06-30-2011 06:22 PM
04:28 AM
