Help!!!! Plz - Mustang Evolution
Old 08-26-2011, 08:53 PM   #1
04machazblue's Avatar
Help!!!! Plz
Okay so I put a new clutch everything torqued to specs went in smooth Not a single problem. Clutch engages And goes into gear smoothly... I am getting a horrible blacking noise almost sounds like a rod nock. Or a bad oil pump but I got pressure. And i can feel it really good in the oil pan. Wen I put my hand on it. Amy advice guys?
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 08-27-2011, 07:11 AM   #2
onesickstang01's Avatar
Push the clutch in and see if it goes away. If it does its probably pilot bearing
onesickstang01 is offline   Reply With Quote
Old 08-27-2011, 12:01 PM   #3
Did that when it Happend it's a new bearing and the and the noise is constat
1st classic need help plz Nate98stang Classic Mustangs 18 08-06-2011 10:16 PM
06:46 PM
