Caster camber plates - Mustang Evolution
Old 08-27-2011, 09:25 PM   #1
Does anyone know If I would need to get caster camber plates for for a lowering kit that only does .75" in the front and .50" in the rear?
zrider07 is offline   Reply With Quote
Old 08-27-2011, 10:53 PM   #2
BayyGT's Avatar
Hm doubt it. Then again I needed it for my drop with the frpp c springs which was about 1"-1.25" which is what they're advertised as. I feel like my front dropped more than that though. Curious as to why such a small drop?
BayyGT is offline   Reply With Quote
Old 08-27-2011, 11:09 PM   #3
Well I need new springs but I didn't really want a big drop. I was hoping for stock height but they don't make performance springs at stock height. So ford racing makes this kit with just a bit of drop for not too bad of a price.
Old 08-28-2011, 12:33 PM   #4
Titus Wadicus
svtlx's Avatar
Re: Caster camber plates
i dont think you dont need c.c. plates for only ".75 drop". typicaly 1.5 or more u need c.c. plates. sum ppl get them for 1.0 drop, but its kinda up to u.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 08-28-2011, 01:10 PM   #5
Ok sweet! That's saves me a couple hundred $$!
Old 08-28-2011, 05:27 PM   #6
if its just .75 or so you will probably be ok overall, but thats such a little drop, unless the rate is stiff you wont notice any difference
J&M camber and caster plates tigercrazy718 General Mustang Discussion 0 07-03-2011 02:06 AM
10:29 AM
