What Throttle Body/Plenum Combo Should I Get? - Mustang Evolution
Old 08-28-2011, 11:47 AM   #1
TheJigShow's Avatar
Now that I finally have my 04 GT, I'm looking to modify it. For an TB/Plenum I was thinking of getting the BBK Throttle Intake (Has a plenum and throttle body in one unit). It has a 78mm inlet. I'm going to be running N/A (if I supercharge it it'll be a Kenne Bell) so I'm curious if 78 is too much. If so what do you recommend?
"Jig"
2014 Ford Focus ST (ST3, Tuxedo Black Metallic)
1997 Ford Mustang GT (Rio Red) (RMR #7832)
2003 Ford Mustang GT Centennial Edition (Black) (SOLD)
2004 Ford Mustang GT (Redfire) (SOLD)
1985 Chevrolet C10 Custom Deluxe (Red) (SOLD)
TheJigShow is offline   Reply With Quote
Old 08-28-2011, 11:54 AM   #2
secomejia's Avatar
In my opinion, there is no need for the throttle body. Get the intake and the tunner togheter. U would get like 30-40 hp with that combo. Im getting the tunner next month. Is a great upgrade for HP!!!
secomejia is offline   Reply With Quote
Old 08-28-2011, 11:56 AM   #3
TheJigShow's Avatar
So you think the BBK intake will be fine coupled with a tune?
"Jig"
Old 08-28-2011, 11:59 AM   #4
secomejia's Avatar
Is the best u could do right now, after that if u want to get the throttle body, just upgrade the tunner to get the best out of you mustang. Like i said the tunner is the next thing in my list
Old 08-28-2011, 12:07 PM   #5
TheJigShow's Avatar
Fair enough. The throttle body is incorporated into the plenum and it's for a great price so I figured I couldn't afford not to lol. And yeah a tuner is next on mine. I'm going to get the one from American Muscle so I get the free Bama tunes for life so I can get tunes for each mod. Then when it's done I'm going to get a tune from Paul's High Performance.
"Jig"
Old 08-28-2011, 02:26 PM   #6
onesickstang01's Avatar
78 is too big for NA. Go 70-75. It does make a difference
onesickstang01 is offline   Reply With Quote
Old 08-28-2011, 02:28 PM   #7
03GT88's Avatar
I have the bbk power plus 70mm and a trick flow Plenum. Works great and gives a nice little whistle when the air is flying in. And it looks a lot better than stock
03GT88 is offline   Reply With Quote
Old 08-28-2011, 02:38 PM   #8
Jamesgt08's Avatar
A CAI does not do much for these year stangs very little if anything. I would get a 75 mm tb and a good plenum and get ur intake and tuner.
Jamesgt08 is offline   Reply With Quote
Old 08-28-2011, 06:43 PM   #9
t0t4lbl4ck0ut's Avatar
Well if you might get a kenne bell don't get the bbk 78 cause you'll have to buy a new one when you get the kb. Get the trick flow 75mm and plenum. You can reuse the tb from that combo with the kb. Also if you might stay n/a I'd probably only go with 70mm anything bigger if not helping at all
---------- Post added at 12:43 AM ---------- Previous post was at 12:41 AM ----------
Or any individual tb that's not a plenum too like the 78mm bbk
t0t4lbl4ck0ut is offline   Reply With Quote
Old 08-29-2011, 06:32 AM   #10
TheJigShow's Avatar
I'll go with the 75mm/plenum combo then. Is trick flow the best option or is there others such as Accufab?
"Jig"
Old 08-29-2011, 06:56 AM   #11
Well there's accufab and bbk but for the price you cant beat the trick flow. I just bought mine the day before American muscle got it. I really don't see how there can possibly be a difference between cheap and expensive throttle bodies, other then maybe valve thickness.
---------- Post added at 12:56 PM ---------- Previous post was at 12:53 PM ----------
I'm gettin a kb too and when your planning on getting something like that you might as well build around that and get things so your wasting as little money as possible
Old 08-29-2011, 11:41 AM   #12
TheJigShow's Avatar
Fair enough. I might not run the KB Blower for quite some time so for an N/A setup that I plan on throwing nitrous maybe I think 70mm will do fine.
"Jig"
Throttle body? Aggiesrok 2005-2010 Mustang GT 6 08-29-2011 07:04 PM
throttle body question..... gkstang Pre-2005 V6 Mustang 1 08-19-2011 07:21 AM
TB plenum combo? Mineralgreygt 1996-2004 Mustang GT 3 07-19-2011 08:37 PM
Throttle Body Spacers jbanks 1996-2004 Mustang GT 5 07-11-2011 08:43 PM
Throttle body cleaning Mustanglife Pre-2005 V6 Mustang 10 07-04-2011 01:32 PM
06:18 AM
