Spark plug and coil pack sudgestions? - Mustang Evolution
Old 08-29-2011, 11:21 PM   #1
p1blake04's Avatar
Have a 04 40th anniversary gt with a built tune done by gearheads performance tranny 4.10gears procharged Anderson power pipe super 44 exaust(dumped) ): bought it with the exaust like that, short t shifter , cai, I'm running autolite plugs right now but need to know what's a good plug and gap so run with boost and also coil packs I have stock coil packs now so I'm open to suggestions?
p1blake04 is offline   Reply With Quote
Old 08-30-2011, 07:25 AM   #2
onesickstang01's Avatar
Stock coils work fine, just as good as any aftermarkets. I run accels though with a very similar setup. Ngk tr6 is what you need to run. Its a step colder which you need for the blower. They run around $2 a plug which is cheap and gap them sround .035. How much power are you making?
onesickstang01 is offline   Reply With Quote
Old 08-30-2011, 08:07 AM   #3
Re: Spark plug and coil pack sudgestions?
yea stock will work fine
Old 08-30-2011, 10:36 AM   #4
p1blake04's Avatar
I'm pushing 9 pounds and I have a safe tune so 410hp I called this one place they said I need tr6's galled down to 2800th s but if what ur saying to run will it be better for boost than my set up now?
Old 08-30-2011, 12:10 PM   #5
now as far as what gap and what heat range for the plugs that will differ no doubt, TR6's are a good plug
Old 08-30-2011, 01:54 PM   #6
It depends if you are getting spark blowout. At 9 psi i doubt it. I run mine at .035 and i have no blowout issues at 13 psi. Most gap between 30-35 thousounths
Old 08-30-2011, 02:39 PM   #7
I have 6 psi with 75 shot of nos. I used to get detonation before with autolites. But then changed to the tr6 and what a difference. Mine are tapped at .028
Dnraiders is offline   Reply With Quote
Old 08-30-2011, 02:40 PM   #8
you cant always hear detonation FYI always best to change them often (5k or so miles~ maybe ever other oil change) look at the ends of them for cracks or issues (signs of detonation)
Old 08-30-2011, 02:45 PM   #9
I do my oil changes monthly and spark plugs every 2.5 months. What we saw was when we had the car on the dyno for 12 days
Old 08-30-2011, 03:17 PM   #10
p1blake04's Avatar
So I should run with tr6s with stock coil packs?
Old 08-30-2011, 06:07 PM   #11
nickysixx's Avatar
I run plugs ngk iridium ix's with 9.5 super conductor msd wires and coil packs
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 08-30-2011, 06:18 PM   #12
p1blake04's Avatar
Idk if I can use iridiums I heard if I used thos I would detonate ? But I have no clue
How Do I Clean Out My Holes? ...spark plug holes? Nel86 General Car Discussion 8 08-06-2011 04:55 PM
Spark plug blown out of head. 1bad2v 1996-2004 Mustang GT 17 07-03-2011 09:29 PM
02:00 AM
