Pinion seal advice - Mustang Evolution
Old 09-06-2011, 06:15 AM   #1
04machazblue's Avatar
Pinion seal advice
Okay well I realized my pinion seal is leaking, figures after I put the clutch In something else would happen lol, I've never attempted to do one but I was thinking it can't be to difficult.
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 09-06-2011, 06:59 AM   #2
Re: Pinion seal advice
I think the hard part is getting the pinion back in and set correctly to avoid gear whine or bad wear patterns
I am not sure if you have to remove anything that alters that in doing a pinion seal but I bet you will have to... thus you may have to let a shop that knows how to setup the rear do it... good time to change gears though
Old 09-06-2011, 08:08 AM   #3
Well I worked at a shop and the master tech there told me he would do it for 25 bucks I just have to purchase the parts but I am not sure if just the seal alone is all to difficult to do, funds are tight spent saved money on my parts for the clutch
Old 09-06-2011, 09:47 AM   #4
onesickstang01's Avatar
Drop driveshaft. Remove pinion nut after measuring the threads that can be seen on the top side of nut. This is important so you have the same amount of drag and pinion gear play. You can also count threads. Once you remove nut with impact gun you will need a puller to remove the knuckle/flange for the driveshaft. Then just pop the seal out and replace. Put all back together. Pretty simple and you dont have to mess with shims or anything
onesickstang01 is offline   Reply With Quote
Old 09-06-2011, 11:43 AM   #5
Well it's leaking a Lil bit and I have to get it fixed so looks like I got my weekend task
Old 09-07-2011, 07:30 AM   #6
Make sure you get friction modifier! It mixes with the gear oil. I think the rroyal purple gear oil has it in it already but not for sure. You need it though so dont forget
Old 09-07-2011, 08:18 AM   #7
93slowstang's Avatar
Royal purple does have it so it's not necessary to add it.
Old 09-07-2011, 08:58 AM   #8
Okay thanks fellas. What weight do u recommend
Old 09-07-2011, 09:16 AM   #9
I think it calls for 75-90 but check with them at the auto parts store they can tell you
Old 09-07-2011, 09:18 AM   #10
I have 75w-90 in mine, its what i was told is the recommended weight.
Suspension advice zrider07 1996-2004 Mustang GT 4 09-07-2011 07:19 AM
Advice 89white GT General Car Discussion 11 08-17-2011 03:38 PM
Rear end advice t0t4lbl4ck0ut 1996-2004 Mustang GT 6 08-07-2011 06:59 PM
paint advice vinnygt 1996-2004 Mustang GT 0 07-09-2011 03:37 PM
Shifter advice Qwik Four Six 1979-1995 Mustang GT 8 07-08-2011 08:58 AM
09:38 PM
