Running Rough. - Mustang Evolution
Old 09-06-2011, 10:30 PM   #1
ColeJohnson's Avatar
Running Rough.
I noticed lately that my '02 GT is running a bit rough at idle. When I get moving or rev the engine up past 1k it stays pretty smooth, but at idle is shakes a lot.
Any ideas? It's not making any weird noises or anything.
2016 Comp Orange GT (current)
Old 09-06-2011, 10:57 PM   #2
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
Re: Running Rough.
i would check your egr valve first, could be a vacuum issue, that seems to be quite easy to notice at idle levels, otherwise i have had it like that off watered down gas before too
gregtommy is offline   Reply With Quote
Old 09-07-2011, 07:24 AM   #3
onesickstang01's Avatar
Sounds like a misfire. Once revved up you wont notice a misfire on a v8
onesickstang01 is offline   Reply With Quote
Old 09-07-2011, 02:09 PM   #4
crkmonzo's Avatar
Re: Running Rough.
does it idle rough on a cold idle, warm idle, is it wet or dry outside? or does it do it all the time
crkmonzo is offline   Reply With Quote
Old 09-07-2011, 02:13 PM   #5
It does it all the time.
Old 09-07-2011, 02:14 PM   #6
crkmonzo's Avatar
Re: Running Rough.
is the check engine light on?
Old 09-08-2011, 01:37 AM   #7
No. And if I turn the ac on then it runs smooth at idle again.. It's so weird.
Old 09-08-2011, 11:32 AM   #8
crkmonzo's Avatar
Re: Running Rough.
it doesnt overheat or anything does it? maybe check the air filters and cabin filter, check coolant level. or even see if the a/c pump clutch pulley is good.
Old 09-08-2011, 11:35 AM   #9
No. Never overheats.
Old 09-08-2011, 01:09 PM   #10
crkmonzo's Avatar
Re: Running Rough.
another thing start checkin vaccum lines
Old 09-08-2011, 01:52 PM   #11
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
check harmonic balance does it shake real bad?
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 09-08-2011, 02:55 PM   #12
It doesn't shake terribly. My passengers can't feel it. I'm just aware of it since I'm driving it so often. And the exhaust sounds like it hiccups out of the driver side pipe every second.
Old 09-08-2011, 02:56 PM   #13
Bballing0416's Avatar
Check the air intake filter
Bballing0416 is offline   Reply With Quote
Old 09-08-2011, 04:13 PM   #14
Holy crap. My air filter is gone!!
Old 09-08-2011, 05:16 PM   #15
00STANG00's Avatar
damn thats not good. how long you think you drivinf without one
SUCK MY DUST
Old 09-08-2011, 06:43 PM   #16
gregtommy's Avatar
What? How
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq
Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence)
Old 09-08-2011, 09:58 PM   #17
I have no idea. It's been idling rough for probably four days. So perhaps that long. I have the CAI that is routed out of te engine bay into the fender.. So I'd imagine someone could steal it.
Old 09-11-2011, 07:32 PM   #18
Well.. Got a new filter and installed it.. No problems now. Lol
Old 09-12-2011, 05:16 AM   #19
Lol. My CAI was loose one time and it was running awful.
Old 09-12-2011, 08:55 AM   #20
Ok. So when the car is cold is shales a bit at idle. But after reaching temperature, is runs smooth at idle. Any ideas?
Old 09-12-2011, 11:48 AM   #21
It does that after you put on a new air filter?
Old 09-12-2011, 01:22 PM   #22
crkmonzo's Avatar
Re: Running Rough.
is it making any noises?
Old 09-12-2011, 02:13 PM   #23
Only a small hiccup in the exhaust.
Old 09-12-2011, 02:44 PM   #24
crkmonzo's Avatar
Re: Running Rough.
idk it almost sounds like when its cold a exhaust valve aint seating right and once it gets up to temp the valve expands and fills up the gap that it didnt have when it was cold, or it could be something small like a bad sensor
Old 09-12-2011, 03:31 PM   #25
I'll have to recheck the sensors.
Old 09-12-2011, 03:46 PM   #26
crkmonzo's Avatar
Re: Running Rough.
that would be the easiest route lol hopefully it is a sensor, like i said idk 100 percent on the valves but it sounds like it could be a symptom, another thing is before when i asked if it only did it when it was wet or dewy outside because once i had a car that ran rough on dewy cold start ups and it was because moisture was getting under a loose distributor cap and making it misfire intill under the cap dried out from the heat.
got her running dreamstang 1979-1995 Mustang GT 33 09-04-2011 11:02 PM
Stay on running lights uh60facilitator Mustang Paint, Appearance & Detailing 0 08-17-2011 12:19 PM
Running lights Gmullinix 2005-2010 V6 Mustang 4 08-12-2011 10:13 PM
94 mustang gt is running hot!!! 94 GT 1979-1995 Mustang GT 20 07-01-2011 02:45 PM
01:59 PM
