99-04 GT Timing Chain tool? - Mustang Evolution
Old 09-09-2011, 02:25 PM   #1
FORDGT14's Avatar
I have to have my timing chain replaced on my 1999 Mustang GT. I have been told that I will need a special tool. Is there anyone who knows about this tool. Like the name of it and where I can purchase it?
And also I am going to have to rebuild the top end of my engine. Will I need any special tools for this?
Thanks guys
FORDGT14 is offline   Reply With Quote
Old 09-09-2011, 02:33 PM   #2
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
i dont know it said in the book bout it cant be adjusted. you might want to call a ford dealer
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 09-09-2011, 02:38 PM   #3
FORDGT14's Avatar
Ok. Does it say anything about needing a tool for a rebuild? Or can i just pull it apart like a normal engine?
Old 09-09-2011, 02:54 PM   #4
00STANG00's Avatar
you cant take it off as far as i know its a chain not a belt
---------- Post added at 03:50 PM ---------- Previous post was at 03:49 PM ----------
ill check
---------- Post added at 03:54 PM ---------- Previous post was at 03:50 PM ----------
ya you can take it off doesnt say what tool to use google it i was always told you cant dam liars
SUCK MY DUST
Old 09-09-2011, 02:57 PM   #5
FORDGT14's Avatar
ill check
Ok cool. Let me know. Ford wasnt much help over the phone. Go figure lol
Old 09-09-2011, 03:03 PM   #6
00STANG00's Avatar
All you need to do is loosen the valve covers and take the front bolts off that connect to the timing chain cover, then you will have to take out the (guessing) 12-15 bolts that hold the timing chain cover on. Then you will have full access to the timing chains but you will need to be careful with he tensioner because when you let the tensioner loose the cams on that side will turn if they are not restricted. This could be very bad if you do not take precautions to keep it from turning. I used vice-grips when I changed mine and it kept it from turning fine. The process isn't hard if you have a basic set of hand tools 10, 13, 15, and 18mm got this from another forum
SUCK MY DUST
Old 09-09-2011, 03:12 PM   #7
FORDGT14's Avatar
Ok thank you for that. It helped alot man. Makes a little more sense now. But when you say "tensioner" are you talking about the belt tensioner on the outside?
Old 09-09-2011, 03:14 PM   #8
00STANG00's Avatar
both have to take the one outside to get to the one inside
SUCK MY DUST
Old 09-09-2011, 03:22 PM   #9
FORDGT14's Avatar
Ok..well wish me luck, its on its way to phoenix and my uncle (certified mechanic) and I are gona take it apart and see what the problem is.
Anyways thanks again for the help man
Old 09-09-2011, 03:25 PM   #10
00STANG00's Avatar
no problem man glad to help
SUCK MY DUST
Old 09-10-2011, 02:06 PM   #11
BayyGT's Avatar
Rotate the crank to safe mode which I believe is the 9 or 1030 position. That way if anything does unexpectedly spin all the pistons are below the deck and won't hit a valve.
BayyGT is offline   Reply With Quote
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
06:28 PM
