Engine swap - Mustang Evolution
Old 09-13-2011, 12:19 AM   #1
96 stang's Avatar
Engine swap
Hey guys I am thinking about doing a 5.4l swap in my 96 gt, I want close to 500hp. Will dohc cobra 4.6l heads fit on the 5.4? Has anyone done this swap?
96 stang is offline   Reply With Quote
Old 09-13-2011, 08:53 AM   #2
onesickstang01's Avatar
You can put 4.6 heads on any 5.4. Going from sohc to dohc is a pain though. You will needs chains guides tensioners and timing cover. You also need either intake adapters or the hardballer intake
onesickstang01 is offline   Reply With Quote
Old 09-13-2011, 09:00 AM   #3
96 stang's Avatar
Okay thanks. I'm going to look in to it more but I'm pretty sure I'm going to try this swap.
Old 09-13-2011, 01:24 PM   #4
Just do a cobra swap if your going to put out a lot if money
16218 is offline   Reply With Quote
Old 09-13-2011, 08:17 PM   #5
96 stang's Avatar
Well I can get alot of what's needed for cheap & I have the 5.4 at home. I wanted to try & put the cobra heads on the 5.4. & intake etc
Old 09-13-2011, 11:26 PM   #6
What 5.4 is it? You'll get some gain but not to much if its like a f150 5.4
Old 09-13-2011, 11:40 PM   #7
96 stang's Avatar
It's out of an 98 expedition. I was thinking of boring it out a little too
Old 09-19-2011, 02:05 AM   #8
96 stang's Avatar
Does anyone know if headers off a 4.6 fit on a 5.4??
Old 09-19-2011, 07:56 AM   #9
93slowstang's Avatar
Yes they will work fine on the 5.4 if they are shorties. If you plan on using longtubes then you will have clearance problems because the 5.4 is wider.
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 06:29 AM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 10:07 PM
Engine Swap BlackBeauty01 1996-2004 Mustang GT 5 07-07-2011 10:15 AM
Engine swap, here we go Mustanglife General Mustang Discussion 65 07-05-2011 09:07 PM
Strange engine swap idea ArmyStang 1996-2004 Mustang GT 25 07-05-2011 11:29 AM
05:06 PM
