trans mount - Mustang Evolution
Old 09-13-2011, 11:12 AM   #1
trans mount
Have been having a loud thunk under the car, finally got under it today and found that my trans mount is completely torn. Any recommendations? OEM replacement or aftermarket. Car is my 04 Mach 1
rix71gt is offline   Reply With Quote
Old 09-13-2011, 11:36 AM   #2
deadsp0t's Avatar
Urethane are mounts are nice, though a little stiffer. I would suggest doing the motor mounts at the same time as some aftermarket mounts come I'm kits and a slight price break.
That's unimpressive
Old 09-14-2011, 07:17 AM   #3
Ok, so I changed the mount and I'm still getting the sound. It only happens when I am turning at very low speed such as parking or pulling in my driveway. It sounds like it is coming from the driveline and can also be faintly heard when engaging first at a stop to pull off. I'm at a total loss here. There is no extra play in the driveshaft or any excess gear lash.
Old 09-14-2011, 09:08 AM   #4
jjsg09's Avatar
They all do that at one point. My 01 and 02 GT's do it. Every time I'm at a stop and I put it into 1st I get a little clunk noise that sounds like it comes from the rear-end.
Old 09-14-2011, 10:11 AM   #5
deadsp0t's Avatar
A friends 97 made noises like that and turned out to be a bad motor mount. With the hood up try cracking the throttle open and shut a few times and watch the engine.. His jumped so harshly we actually stepped away from it.
That's unimpressive
Old 09-14-2011, 01:29 PM   #6
Is it possible its the limited slip clutches?
Old 09-16-2011, 09:05 PM   #7
deadsp0t's Avatar
I broke my rear sway bar right where it bolts to the right rear control arm and it made noises during gear changes. But not sitting still. Far as rear end clutches making noise I haven't a clue but does not sound probable or likely. I have herd of busted control arm bushings being noisy, making clunking and slapping sounds just like my broken sway bar did. Your going to have to get under there and look around closely and see what you see.
That's unimpressive
Old 09-17-2011, 02:34 PM   #8
Supersnake4.6's Avatar
Check your u joints also if there worn they can cause this noise it happend to my 98 gt
Supersnake4.6 is offline   Reply With Quote
Old 09-17-2011, 03:02 PM   #9
deadsp0t's Avatar
Good point
That's unimpressive
New trans! nickysixx 1996-2004 Mustang GT 2 08-17-2011 06:12 AM
Trans Downshift Jolt crkmonzo 1979-1995 Mustang GT 3 08-16-2011 08:35 PM
Major AODE trans 94mustanggt5.0 1979-1995 Mustang GT 18 08-12-2011 09:18 PM
Trans 91gt 1979-1995 Mustang GT 3 08-03-2011 01:39 PM
Front Mount Intercooler 95 3.8 achubbard Pre-2005 V6 Mustang 2 07-27-2011 12:37 PM
02:41 PM
