Lowering Springs - Mustang Evolution
Old 09-16-2011, 12:17 PM   #1
559Danny's Avatar
Lowering Springs
My plan is to get some black staggered 18 inch Bullitt wheels. I also want to lower my 03 Mustang GT. Which springs would be the best looking, the most comfortable, and that won't rub the tires after the install? Thanks!
559Danny is offline   Reply With Quote
Old 09-16-2011, 01:54 PM   #2
Re: Lowering Springs
if you go any lower than 1.25 inches you will start to have issues getting places (rubbing your front bumper on the ground etc)
Most aim for 1.5 inches~ not a huge issue here but just FYI you have to be more careful getting into places.
I am at about 2 inches lower than stock. I like a 2 inch gap fender to tire~ or there about.
there are MANY MANY spring choices, your stock rate is probably around 400 front/200 rear so you will want to buy springs around that to keep the ride soft
when lowering more than an inch you will probably need caster/camber plates so you can align the vehicle.
Those are about 180 bucks, springs should be 200-250 depending, installation is NOT HARD (read our how to) or you can pay someone 200-300 to do it.
If you buy OEM ford 18in rims like FR500s they will fit just fine with no rubbing, what rims are you looking at
Old 09-16-2011, 02:21 PM   #3
559Danny's Avatar
Wow that was wry informative, thanks!
I want some 18 inch Bullitt wheels
Old 09-16-2011, 02:44 PM   #4
the backspacing on 18x10 rims should be around 6.5 inches for the rear~ there about
Old 09-16-2011, 08:50 PM   #5
98gtdriver's Avatar
I have thr eibach sport spring and its not that bad of a ride! It dropped it about 1.5 in rear and 1.75 in front. You will need an alignment though
-Eric
98gtdriver is offline   Reply With Quote
Old 09-17-2011, 06:02 PM   #6
edross's Avatar
i have staggered 18 inch bullits with H&R race springs, they are a little on the firm side but thats what you want
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Lowering springs 89white GT 1979-1995 Mustang GT 13 08-31-2011 09:32 AM
Lowering springs 89white GT AmericanMuscle 1 08-30-2011 04:11 PM
lowering springs secomejia 1996-2004 Mustang GT 2 08-15-2011 10:51 AM
Lowering springs Mineralgreygt 1996-2004 Mustang GT 9 08-07-2011 06:58 PM
Lowering springs. GoldenPonyBoy 2005-2010 V6 Mustang 13 07-26-2011 06:40 PM
05:54 AM
