Which engine do i have ? - Mustang Evolution
Old 09-18-2011, 12:01 AM   #1
Bought a 1996 Mustang GT last fall from a friend. He told me that the engine was out of a 2003 police crown vic. It is a 4.6 liter ford engine, but i cant seem to discern which 4.6 liter engine i have. How can i tell ? It does have 2 distributors with msd ignition. Any ideas ?
Thanks
glwharton is offline   Reply With Quote
Old 09-18-2011, 12:12 AM   #2
MonteCitan's Avatar
Re: Which engine do i have ?
Not entirely sure on 03 but the 04 was rated at 250 HP..
Best way to tell if you have the 'PI' motor, examine the valley as best you can (beyween cyl heads/behind alternator) at the top of the block UNDER the intake, if you can see it clearly and there is a TON of room, you have a non pi intake. if the intake is REALLY deep and almost touches the top of the block then its a pi intake. Also the intake opening will go towards the drivers side of the car, not passenger
If they did use a crown vic engine but not the intake manifold, the non-pi intake will be choking your motor..
If you have the PI intake, chances are you have the heads, as well - I can't remember if they're marked or not, but you can pull the intake.. If the heads have an oval shape to them they are non-PI and not from a 2003 crown vic
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 09-18-2011, 09:42 PM   #3
What do you mean by "choking your motor" ?
Thanks
Old 09-18-2011, 11:51 PM   #4
MonteCitan's Avatar
Thanks
Before going into any more detail.. Have you looked at the intake manifold yet? Is there a gap below it or does it mostly fill the valley?
Old 09-19-2011, 12:34 AM   #5
93slowstang's Avatar
Here is what the intakes look like from the top. The one on the left is the non pi and on the right is the pi intake.
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
4.2L engine from a 98 3.8L bmabbott Pre-2005 V6 Mustang 11 07-01-2011 09:09 PM
02:23 PM
