Finally in the 12's - Mustang Evolution
Old 09-21-2011, 03:08 PM   #1
67mustang97's Avatar
Region: Vermont
Finally in the 12's
This last Saturday I finally ran a 12.69 @ 108.9mph. I never imagined how much time work and money it takes to get a 99-04 Stang in the 12's. Should have bought a Terminator to start! But anyway a battery relocation with a Snow Stage 2 meth kit to be installed this Saturday, going to run mid October hoping to get 12.3's @ 110. Does this seen like a realistic goal or am I setting my goals to high?
Old 09-21-2011, 03:16 PM   #2
Las0mbra's Avatar
What all has been done to it?
Old 09-21-2011, 03:26 PM   #3
Region: Vermont
Re: Finally in the 12's
Vortech V3 @9psi, Anderson power pipe, BBK headers, BBK off road x pipe, Flow Master cat back, Granatelli coils, SCT custom tune, 4:10's, Aluminum flywheel / drive shaft, State 2 clutch, Pro Products 75mm throttle body, Pro Products upper intake plenum, Hurst shifter, Mickey Thompson DR's
Old 09-21-2011, 03:38 PM   #4
Brett Greene's Avatar
All that for 12s. Turn the boost up brotha
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 09-21-2011, 03:45 PM   #5
Region: Vermont
Don't think the stock engine can take much more boost. It sucks starting with 260 hp compared to new cars! But at least I beat a new Camaro!
Old 09-21-2011, 03:47 PM   #6
Mm yes I don't know much bout these cars. What about some heads n cams?
Old 09-21-2011, 03:53 PM   #7
Region: Vermont
I could do heads and cams but I think the bottom end can only take around 420rwhp. I'll have to do everything to be safe.
Old 09-21-2011, 04:17 PM   #8
93slowstang's Avatar
Find a good 4v out of a wrecked cobra and start on that.
Old 09-21-2011, 06:27 PM   #9
onesickstang01's Avatar
Im running almost the exact same setup making 440 rwhp. Im using a 2.95 pulley and its hiting around 13-14 psi and its safe. Boost it a little more and you will be happy. Not sure if you have it or not but you will need a boost a pump for sure
onesickstang01 is offline   Reply With Quote
Old 09-21-2011, 07:05 PM   #10
Region: Vermont
What times and speed are you getting at the track? Before my power pipe I made 336 rwhp so I may be in the 350 rwhp range now? I'll post my numbers after I get it tuned for meth. I don't have a boost a pump yet.
---------- Post added at 09:05 PM ---------- Previous post was at 09:04 PM ----------
Do you have any belt slipping problems with a smaller pulley?
Old 09-21-2011, 07:25 PM   #11
I havent taken it to the track lately. I would guess somewhere in 11s if i can get some traction. No belt slipping issues. Vortechs dont really have many problems with that. The power pipe really does make some difference and you will really need a boost a pump and a good 255 pump. Walbro finally came out with one for our returnless fuel system. Not cheap but im happy with it
Old 09-21-2011, 07:35 PM   #12
2001 GT 5sp
Kenne bell 2.1 9 psi intercooled
Kooks 1 5/8" LT's
Kooks catless X
SLP LM 1's
3.27 gears Spec stage 2 clutch with steel flywheel
Street tires 285's in the rear
406 whp/446 wtq
92 degrees outside
12.54 @ 110 and 1.87 60ft Lund tuned
Not much further ahead to get a cobra IMO. I paid 8750 for my car with 49K. A termi probably would have costed me 13 to 15 grand and stock it won't run what I did with mine and I like my solid axle for the strip.
It would be nice to have the fuel system though of the cobra. I am maxxed out at 406whp with Boost a pump and stock pump
ajpturbo is offline   Reply With Quote
dad finally gave up the keys jcford New Member Introductions & Greetings 37 11-19-2011 10:36 AM
Finally bought my new 2004 TheJigShow 1996-2004 Mustang GT 21 10-04-2011 06:52 PM
suspension is finally installed! tigercrazy718 2005-2010 Mustang GT 8 08-18-2011 11:09 PM
So finally....2001 SVT COBRA BABY!! shazzsk89 General Car Discussion 34 07-20-2011 10:49 AM
Finally Arrived! Gmcnomore 2011-2014 V6 Mustang 17 06-30-2011 08:27 PM
01:27 PM
