09-23-2011, 11:29 AM
#1 | | Registered User
| 4.10 Gear Speed/RPM Video
Everyone seems to be really scared about changing out their stock 3.27 gear with a steeper gear like 3.73, 3.90, or 4.10. I elected to go big or go home and went with the 4.10s. And I'm so happy I did! Here's a video to put to rest all the stories about how terrible the gas mileage is and how much it affects your car... This is a video of me on the interstate running at 65mph, 70mph, 75mph, and finally 80mph. The speedometer and RPM gauge is all correct thanks to my tuner.
Don't fear the gear! 4.10 is amazing! 4.10 Gear RPM/Speed Example Video - YouTube |
09-23-2011, 02:13 PM
#2 | | Titus Wadicus
| Re: 4.10 Gear Speed/RPM Video
im glad u made that video... it definatley makes me wanna stay away from 4.10's for a highway driven car. im gonna assume you have stock injectors.. i definatley cant afford that kinda 65-70mph rpm with 30lbs inj.
if i had a 6spd i think i would be all over it.
again, thanks for the video.. it clarified things for me
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
09-23-2011, 02:51 PM
#3 | | Senior Member
Excellent idea!
__________________ |
09-23-2011, 03:16 PM
#4 | | Registered User
| Quote: |
Originally Posted by svtlx im glad u made that video... it definatley makes me wanna stay away from 4.10's for a highway driven car. im gonna assume you have stock injectors.. i definatley cant afford that kinda 65-70mph rpm with 30lbs inj.
again, thanks for the video.. it clarified things for me | Heard that! Glad it helped you make your decision! And yeah, I still get over 20mpg cruising 65 on the interstate. Lol. Stock injectors.
09-23-2011, 09:03 PM
#5 | | Registered User
Oh, and just to add to this. 4.10 adds about 300-400rpm on a stock gear of 3.27 with the tremec 3650 5speed. So 3.73 will be slightly less than this but still a relatively noticeable difference. I'd guess in the 200-300rpm increase range. City mpg will go up if you short shift, and hwy mpg will only go down by 1-4mpg.
The reason people seem to see such bad gas mileage is because it's so hard to not stand on it all the time. And third and fourth gear finally do something so hwy and interstate driving is much more fun! When I stay in the throttle I can get down to 12-15mpg. Lol
It's so worth it.
09-24-2011, 06:55 AM
#6 | | Registered User
I do all city driving in my car, so with 4.10's I should get better mpg then or maybe 3.73?
09-24-2011, 06:59 AM
#7 | | Legacy Member
| Re: 4.10 Gear Speed/RPM Video Quote:
Originally Posted by jjsg09 I do all city driving in my car, so with 4.10's I should get better mpg then or maybe 3.73? | For the most part yes, you can always have a heavy foot and get lower mileage, but for the most part you will see an increase in normal city traffic.
Mine: -03 SB Cobra vert- 2552 of 5082 Born 02/25/03
Our's: 90 7up vert - new project-07 DSG Focus -DD 335 |
09-24-2011, 08:59 AM
#8 | | Registered User
Originally Posted by lowflyn For the most part yes, you can always have a heavy foot and get lower mileage, but for the most part you will see an increase in normal city traffic. | That is correct. But if you love the sound of your car in higher RPMs.. Your MPGs can always dip way down. But if you behave yourself it does increase city mpg. :]
09-24-2011, 09:37 AM
#9 | | Registered User
| Quote: |
Originally Posted by ColeJohnson
That is correct. But if you love the sound of your car in higher RPMs.. Your MPGs can always dip way down. But if you behave yourself it does increase city mpg. :] | Well the thing I hate the most about the stock gears is, it feels like 3-4 has no power in it. Just wondering if its worth the swap if I do get worse mpg. My 02 GT is a daily driver right now.
09-24-2011, 09:58 AM
#10 | | Registered User
Originally Posted by jjsg09 Well the thing I hate the most about the stock gears is, it feels like 3-4 has no power in it. Just wondering if its worth the swap if I do get worse mpg. My 02 GT is a daily driver right now. | My '02's 3rd and 4th really woke up! I'm completely satisfied with it and it's completely worth any mpgs less. Remember.. With Mustangs, we more or less base ourselves on smiles per gallon. :p
09-24-2011, 10:05 AM
#11 | | Registered User
| Quote: |
My '02's 3rd and 4th really woke up! I'm completely satisfied with it and it's completely worth any mpgs less. Remember.. With Mustangs, we more or less base ourselves on smiles per gallon. :p | Ha! Love it
09-28-2011, 06:15 AM
#12 | | Registered User
| Re: 4.10 Gear Speed/RPM Video GOOD Post.
07 GT. SCT: CUSTOM TUNED by MUSTANG SPECIALTIES. STEEDA: CARBON FIBER CAI. FRPP: 410 GEARS. MAGNAFLOW: AGGRESSIVE EXHAUST. BBK: LONG TUBE HEADERS & X PIPE. MSD: COIL PAK. CROSS DRILLED ROTORS. STAGGERED 22" WHL 22X8.5F-22X10R. |
09-28-2011, 07:46 AM
#13 | | Registered User
another thing to point out: from my research if your ever gonna supercharge with a roots or twin screw type blower, 4.10s are gonna be pretty brutal. no 1st gear at all lol. idk about centrifugal sc's tho
2008 V6
204 RWHP Quote: |
Originally Posted by Brent If you wreck and kill yourself trying to jerk off on the way to her house I will put it all over the internet. | |
09-28-2011, 09:19 AM
#14 | | Registered User
| Quote: |
Originally Posted by tigercrazy718 another thing to point out: from my research if your ever gonna supercharge with a roots or twin screw type blower, 4.10s are gonna be pretty brutal. no 1st gear at all lol. idk about centrifugal sc's tho | Good point. It's said that if you go forced induction at all, really, then you should stick with something more like a 3.55 or even stock 3.27.
09-28-2011, 10:11 AM
#15 | | Registered User
Even with my vortech and 373s first and second are useless. I run nitto 315 widths on rear and still dont hook. I drive around town always startin in second gear for normal driving. I love the gears and the way they pull but if going big power they hurt a little
09-28-2011, 11:36 AM
#16 | | Registered User
Originally Posted by onesickstang01 Even with my vortech and 373s first and second are useless. I run nitto 315 widths on rear and still dont hook. I drive around town always startin in second gear for normal driving. I love the gears and the way they pull but if going big power they hurt a little | luckily since im missing 2 cylinders when i get a blower i wont have that problem lol
2008 V6
204 RWHP Quote: |
09-28-2011, 12:33 PM
#17 | | Registered User
Originally Posted by ColeJohnson Everyone seems to be really scared about changing out their stock 3.27 gear with a steeper gear like 3.73, 3.90, or 4.10. I elected to go big or go home and went with the 4.10s. And I'm so happy I did! Here's a video to put to rest all the stories about how terrible the gas mileage is and how much it affects your car... This is a video of me on the interstate running at 65mph, 70mph, 75mph, and finally 80mph. The speedometer and RPM gauge is all correct thanks to my tuner.
Don't fear the gear! 4.10 is amazing! 4.10 Gear RPM/Speed Example Video - YouTube | Also I would like to add that for an automatic-equipped vehicle, the RPMs with the 4.10 gears will be 100-200 lower than a manual-equipped vehicle. This kinda goes for all gears. So while a popular choice for manual cars is a 3.73, people whom have autos will feel a similar gain in power from a gear much steeper like a 3.90 or 4.10. ---------- Post added at 01:33 PM ---------- Previous post was at 01:25 PM ---------- Quote:
Originally Posted by ColeJohnson Also I would like to add that for an automatic-equipped vehicle, the RPMs with the 4.10 gears will be 100-200 lower than a manual-equipped vehicle. This kinda goes for all gears. So while a popular choice for manual cars is a 3.73, people whom have autos will feel a similar gain in power from a gear much steeper like a 3.90 or 4.10. | And one more thing! People say that the steeper gear you get, the less top-end you'll have in terms of MPH. This is completely false in so many ways- especially if you have a brain and can think. With a relatively stock car, you reach 5th gear at around 105mph if you're going all the way through the RPM band. Then when you shift into 5th with stock 3.27s, your RPMs hit around 2k-2.5k. The powerband is around 3k+, but seeing as how 5th is an overdrive gear, it's very difficult for your car to get into peak RPMs around 4k-4.5k and you usually end up hitting maybe 110 then acceleration almost stops.
However, with 4.10s, at 105 I hit 5th gear and my RPMs are already right over 3k, and then soon they're over 4k and I'm going around 125, then at 5k I'm at 135, and I've gotten up to 143mph at around 5.5k. When I had stock 3.27 I was maybe getting 120 if I was lucky. With the steeper gears, the engine is allowed to work at a more efficient RPM and doesn't get bogged down.
So yeah... The only downside to steeper gears is:
1) Lower MPG(but only barely if you drive nicely)
2) You burn out a lot
3) First gear becomes pretty useless.
Upsides:
1)Accelerate like a bat out of hell (versus stock gears)
3) Your engine works at more optimal RPMs in pretty much every gear
4) City driving is easier because it takes less effort to start rolling
5) Passing on HWYs and Interstates is fun/safe again.
6) There are more, but I gotta get going to work. Lol Can't wait to drive my car!!
09-29-2011, 06:02 AM
#18 | | Registered User
| Re: 4.10 Gear Speed/RPM Video Good stuff/good Info, thanks for that Info.
As you have probably read, I have the 4.10's with an Automatic and I am thinking of getting the "Saleen" SuperCharger on mine, what's your opinion on that setup/choice?? I've read resently alot of opinions on Gears and SuperChargers, particularly the First and Second Gear being useless, do you think I will have that problem???? Quote:
Originally Posted by ColeJohnson Also I would like to add that for an automatic-equipped vehicle, the RPMs with the 4.10 gears will be 100-200 lower than a manual-equipped vehicle. This kinda goes for all gears. So while a popular choice for manual cars is a 3.73, people whom have autos will feel a similar gain in power from a gear much steeper like a 3.90 or 4.10. ---------- Post added at 01:33 PM ---------- Previous post was at 01:25 PM ----------
Upsides:
6) There are more, but I gotta get going to work. Lol Can't wait to drive my car!! |
09-29-2011, 11:06 AM
#19 | | Registered User
Originally Posted by KATO Good stuff/good Info, thanks for that Info.
As you have probably read, I have the 4.10's with an Automatic and I am thinking of getting the "Saleen" SuperCharger on mine, what's your opinion on that setup/choice?? I've read resently alot of opinions on Gears and SuperChargers, particularly the First and Second Gear being useless, do you think I will have that problem???? | yup probably lol. u might need to switch back down to 3.55s
2008 V6
204 RWHP Quote: |
09-29-2011, 11:12 AM
#20 | | Registered User
| Quote: |
As you have probably read, I have the 4.10's with an Automatic and I am thinking of getting the "Saleen" SuperCharger on mine, what's your opinion on that setup/choice?? I've read resently alot of opinions on Gears and SuperChargers, particularly the First and Second Gear being useless, do you think I will have that problem????  | Honestly with an auto you might get away with it.. Especially if you pick and choose your races.
09-29-2011, 11:51 AM
#21 | | Registered User
| Re: 4.10 Gear Speed/RPM Video Thanks Cole, and tigercrazy, i've heard and spoken to a few people, and they said that with my Automatic and the 4.10 Gears, that I would be OK.
09-29-2011, 12:13 PM
#22 | | Registered User
| Quote: |
Originally Posted by KATO Thanks Cole, and tigercrazy, i've heard and spoken to a few people, and they said that with my Automatic and the 4.10 Gears, that I would be OK. | Yeah, like I said you should be able to get away with it. You're just going to have to learn how to control your car's acceleration from a dig. But that experience comes with time. It's gonna be a really fun car!
