Ok. This is really bothering me.. - Mustang Evolution
Old 09-25-2011, 10:16 PM   #1
98StangKid's Avatar
Ok. So my 98 GT is cutting up.(Posted an earlier thread about this, but the problem has worsened.) It's mostly right when I start the car up, at low rpm's, or when I just straight-up punch it. Its almost like a power surge.. Or maybe like the engine is missing? You can even see the lights dim. I'm really wanting to fix this quick, but I need to know how much of a in-depth problem this is, and maybe find someone who has had a similar problem.. I cleaned my K&N today and my MAF looked pretty clean. I've searched all over the internet and can't find a truly relevant answer. Please help me.
'01 Cobra
Forged Internals, Limited Slip Differential, 3:73s, Bama Tune, Pro 5.0 Short Shifter, Mach 1 Air Intake, 31 Spline Moser Axles.
98StangKid is offline   Reply With Quote
Old 09-25-2011, 10:28 PM   #2
96 stang's Avatar
I've been having a problem similar to this but my lights don't dim. I have no idea what it could be.
96 stang is offline   Reply With Quote
Old 09-25-2011, 10:30 PM   #3
98StangKid's Avatar
Yea.. It's crazy.. And it is really making me mad because it is really cutting into my power.. W
'01 Cobra
Old 09-25-2011, 10:32 PM   #4
96 stang's Avatar
I know what you mean it kind of feels like it's hesitating or something.
Old 09-25-2011, 10:33 PM   #5
98StangKid's Avatar
Yep. But I have no idea what it could be.. Maybe someone on here does..
'01 Cobra
Old 09-25-2011, 10:37 PM   #6
96 stang's Avatar
Yea hopefully someone can help out
Old 09-25-2011, 10:40 PM   #7
Re: Ok. This is really bothering me..
Maybe you have some bad O2 sensors that are not working very well until they warm up good.
Old 09-25-2011, 10:43 PM   #8
98StangKid's Avatar
Well if I am not mistaken, my o2 sensors are disconnected due to the fact that I have no cats.
'01 Cobra
Old 09-25-2011, 11:09 PM   #9
Well, you need the O2 sensors so the computer can figure out the best A/F tune for your engine whether you have the cats or not.
Old 09-26-2011, 07:16 AM   #10
98StangKid's Avatar
Ok. I'll get it checked out. I am still a little new to this. Haha. As you can tell. Its crazy how something like that could make my car act up like it is doing..
'01 Cobra
Old 09-26-2011, 07:35 AM   #11
We were all new to this at one time or another, just learn as you go.
Yeah, the computer (ECU) uses them to determine the proper air to fuel ratio (A/F), so if it is not getting a reading from them your car will run pretty crappy.
Old 09-26-2011, 07:37 AM   #12
98StangKid's Avatar
Alright then. Maybe I can run it up to the shope sometime this week and get it checked out.. Or is that something I could do?
'01 Cobra
Old 09-26-2011, 07:51 AM   #13
onesickstang01's Avatar
Clean the MAF. Our cars are very touchy with them. Use MAF cleaner only. Change fuel filter. Check fuel pressure. Look over plug wires for arching. You will see either black ir white marks on the outside of the wires if they are. If you see that obviously replace them. Check plugs see if gapped correctly and see if they are white on the tips. If crusty white you are running lean. Make sure they arent black and wet either. They should be a tan color. That basically covers most of the things you need to check. Scan for codes for cam sensor ect. If you dont have cats you will have two 02 sensors instead of the original 4. So you are half way correct. You could do an induction service too
onesickstang01 is offline   Reply With Quote
Old 09-26-2011, 08:32 AM   #14
Good points.
I forgot about the 4 sensors on these cars, Thank you.
Just curious, what is an "induction service"?
Old 09-26-2011, 08:52 AM   #15
Having the rear O2 sensors off is normal with no cats and a good tune. But I would suspect that the plugs/wires are bad or something. The lights dimming is a little weird though. Specially if it is just a miss.
Old 09-26-2011, 09:22 AM   #16
01StangGt's Avatar
Check the iac and clean the throttle body, change out plugs and wires, fuel filter and check fuel pressure. Could be that you o2 sensor is connected and pushing more fuel into the injectors causing misfires. I would def put the cars back on replace o2 sensors. Are you getting horrible gas mileage?
01StangGt is offline   Reply With Quote
Old 09-26-2011, 09:35 AM   #17
deadsp0t's Avatar
Don't the 4.6L sn95's need a mil connector to keep the CEL off? If the CEL is on you could check those? Also if the problem is affecting the emissions(ie:O2 sensor) it's supposed to set off the CEL on 96 and newer cars w/ OBD 2 right? Is the CEL on?
That's unimpressive
Old 09-27-2011, 05:57 AM   #18
jjsg09's Avatar
Yea you need mil cords if you don't have a tuner that does the same thing. Damn those O2 sensors!
Old 09-27-2011, 08:59 AM   #19
wereKEV's Avatar
I had a 98gt and when ever I would punch it the charge light would come on and the lights would dim I never figured out what it was before I traded it in on my 06gt.
wereKEV is offline   Reply With Quote
Old 09-27-2011, 09:55 AM   #20
RedGT04's Avatar
I had a 2002 Mustang V6 taht did exactly what urs is doing and sometime it will just die in the middle of the road. When I change the alternatoreverything started happening and so I was with my dad and he had a voltage meter, well the problem was that a wire was lose making me lose power and my head lights will go crazy.
RedGT04 is offline   Reply With Quote
Old 09-29-2011, 03:56 PM   #21
Codysmustang's Avatar
Well maybe someone can tell me what going on with my car... Everything started happening after changed the clutch on my car.. When I start my car everything fine.. But after I start going and start to come to a stop my car dies.. If I not completely stopped most times the rpm jumps back up and just goes every where.. But other times depending how slow it just turns off.. I have changed vacuum lines.. Egr valve.. Idle control valve.. Throttle control sensor.. Nothing working.. I starting to get mad because I losing gas milage every time I have to restart my car.. Someone please help
Codysmustang is offline   Reply With Quote
Old 10-01-2011, 06:32 PM   #22
I had the same problem with my 99 gt at weird times I would lose power lights would dim and radio would cut off over a period of about four months it happened then my charge light would go on and off then it stayed on for about a week and alternator went out. After I put the new alternator on, my car hasn't done it. You might want to take it to autozone or a place were they can test alternators dont know if it would show it being bad if it just happens sometimes though
Bparri1 is offline   Reply With Quote
Old 10-01-2011, 06:34 PM   #23
Well I work for ford and got a tech to look at it and said battery was good.. Idk I running out of ideas
Old 10-02-2011, 12:44 PM   #24
94 Mustang GT's Avatar
If there is an issue with the o2 or anything to turn the check engine light on the PCM will use predetermined value for the a/f ratio. If it was his o2 sensors he wouldn't experience that bad of a problem.
---------- Post added at 01:44 PM ---------- Previous post was at 01:41 PM ----------
Does it act up when the engine is warm? Does it act up while driving!?
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 10-02-2011, 01:14 PM   #25
98scstanggt's Avatar
im having the same problem in my 98gt. im gettin really bad gas mileage. i stop car at a red light and it feels lik the car just shut off n rpms drop down
98scstanggt is offline   Reply With Quote
Old 10-02-2011, 01:21 PM   #26
Really?
What I based my reply on was personal experience.
I had a 95 GT that exhibited most of the symptoms except for the dimming lights.
It showed no CEL or codes, yet it turned out to be the O2 sensors.
Old 10-02-2011, 01:39 PM   #27
It bay be the o2 sensors cuz I got idk how many codes for them
« Swap? | Tire size »
10:25 AM
