Should I leave the cats on or off? - Mustang Evolution
Old 09-26-2011, 12:45 PM   #1
RedGT04's Avatar
I just recently purchased a 2004 Ford Mustang GT and I was debating wheather or not to remove my cats ? What do you think I should do? btw I live in Florida and we do not have to go through emissions every year.
RedGT04 is offline   Reply With Quote
Old 09-26-2011, 01:09 PM   #2
onesickstang01's Avatar
Get them out. You will be happy you did
onesickstang01 is offline   Reply With Quote
Old 09-26-2011, 01:27 PM   #3
nickysixx's Avatar
Get a nice sounding cat back and o/r xpipe. X pipe evens out the sound and will eliminate the cats.
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 09-26-2011, 02:37 PM   #4
RedGT04's Avatar
Re: Should I leave the cats on or off?
I was thinking about putting a OFF-ROAD mid pipe in there but im not sure if I wanna do that yet. how much HP would i lose by taking them off ? oh does anybody know about any Mustang meetings in Florida by any chance I live in Tampa
---------- Post added at 02:37 PM ---------- Previous post was at 02:05 PM ----------
also if I decide to take them off would my check engine light would be on?
Old 09-26-2011, 03:22 PM   #5
DSGstang513's Avatar
Yes your check engine will come on get a tuner and also delete your rear o2s
DSGstang513 is offline   Reply With Quote
Old 09-26-2011, 03:25 PM   #6
RedGT04's Avatar
What if they put the O2's back in the mid pipe? that should stop the check engine light to come on right?
Old 09-26-2011, 07:49 PM   #7
CodyNelson's Avatar
Region: West Virgina
No, the CEL will still come on
Old 09-26-2011, 08:03 PM   #8
BlackGT's Avatar
You have 3 options to get rid of the check engine light. Mil eliminators they just plug in you can get them on Americanmuscle.com I think there like 70 to 80 bucks.
You can also get non foulers they just recess the sensor back a little bit and although not as reliable they worked on my friends 2003GT. probably the cheapest.
Or you can get a tuner to simply shut them off. This is the best way to do it but also the most expensive. A performance shop could probably do this for you but not a clue what they would charge you.
BlackGT is offline   Reply With Quote
Old 09-27-2011, 07:20 AM   #9
RedGT04's Avatar
yeah I am just gonna have to get a tune uo eventually, I just do not want to drive around with my check engine light on. my friend had a 2008 Mustang GT and took the cats off of it and the check engine light never came on
Old 09-27-2011, 10:27 AM   #10
RedGT04's Avatar
if i was to go with the MIL Eliminators will my car run rich? or thats only if i dont put the mil eliminators?
Old 09-27-2011, 10:31 AM   #11
loud gets old, just FYI
Old 09-27-2011, 10:43 AM   #12
RedGT04's Avatar
yeah I know but this is not going to be daily driving car, I wanna restore the car and make it look good.... thanks for letting meknow tho
---------- Post added at 10:43 AM ---------- Previous post was at 10:38 AM ----------
btw SpectorV the 2003 Cobra you have is sick, whats the size of your front wheels?
Old 09-28-2011, 09:40 AM   #13
Tib
Tib's Avatar
if it's a daily drive, it gets old real quick.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 09-28-2011, 01:08 PM   #14
RedGT04's Avatar
it wont be my daily ride so thats a plus .... I think im going to take them off and I just purchased the MIL eliminators to get rid of my check engine light.
Old 09-28-2011, 05:54 PM   #15
BlackGT's Avatar
Your car will not run any richer or leaner with or without the eliminators. Your rear O2 sensors (post cat) simply monitor the condition of your cats, nothing more.
The oxygen sensors before the cats are there to monitor the oxygen levels in the exhaust so the computer can calculate the proper amount fuel to dump to obtain the proper air fuel ratio (14.7/1) 14.7 parts air and 1 part fuel. This is the desirable fuel ratio because your cats operate at there peak efficiency.
Old 09-28-2011, 07:07 PM   #16
RedGT04's Avatar
I took them off today put some flowmasters and a offroad midpipe it sounds so good I love it ... I thought I will let u guys know and btw thank you for the info
Old 09-28-2011, 07:29 PM   #17
BlackGT's Avatar
Ya no problem
Old 09-28-2011, 07:30 PM   #18
RedGT04's Avatar
It sounds so good I love it
Old 09-28-2011, 07:33 PM   #19
BlackGT's Avatar
Originally Posted by BlackGT
Ya no problem
I like when people have technical questions. I enjoy picking at my brains a lil bit. Im an automotive technician fully certified so if you have any questions let me know.
Old 09-28-2011, 07:58 PM   #20
RedGT04's Avatar
Yeah deffly man thanks for offering .... I actually have a quick question my abs light is on and traction control doesn't work what do u think it might be ? Btw sometimes the light won't come on and the traction control works all the sudden
Old 09-28-2011, 08:36 PM   #21
BlackGT's Avatar
The most common are wheel speed sensors going bad. They could be intermittent also hence why the light goes out. Both the traction control and antilock brake system rely on these sensors to work properly which is why the traction control doesn't work either. The sensors monitors the rotational speed of each individual wheel. If a wheel were to lockup while braking the sensor would pick it up and communicate it to the abs pump. Then the pump will relieve brake pressure to that particular wheel preventing lockup. Traction control will also monitor the speed and if it picks up a wheel slipping the computer will cut back power from the engine. What you need to do is put a scantool on it and find the trouble code and determine what wheel speed sensor is acting up. Check the connection and the wire alot of times debris can brake the wire. If everything checks out it's probably the sensor. What part of Florida are you from?
Old 09-28-2011, 09:56 PM   #22
RedGT04's Avatar
Thanks for all that info I'm actually going to have my car in the shop tomorrow and do some maintenance done to it .... I just purchased the vehicle last Thursday so I haven't got a chance to play with it.... I'm from the Tampa bay area u
Old 09-29-2011, 05:27 AM   #23
BlackGT's Avatar
I live in jersey but I have alot of family in Florida. Some in palm coast and some in Naples and I wanna move down somewhere around palm beach.
Old 09-29-2011, 07:34 AM   #24
RedGT04's Avatar
That's Miami area.... If u ever come down here let me know and we will cruse I'm joinin a club this sat and we. Gonna have about 100 mustangs going from Tampa to Orlando can u imagine seeing all that in the high way
Old 09-29-2011, 12:37 PM   #25
BlackGT's Avatar
That would be sick
Couple pics of the mustang so you know what I'm working with. You got any pics?
Old 09-29-2011, 12:39 PM   #26
BlackGT's Avatar
BlackoutGT is my forum name on NJ stangers. In case you were wondering
Old 09-29-2011, 01:35 PM   #27
RedGT04's Avatar
Yeah go to my gallery there is bout 4 pics of it ... Keep in mind I just got the car about a week ago so all I done to it is take the cats off and put flowmasters
Old 09-29-2011, 06:07 PM   #28
Mustang_gt_03's Avatar
Region: New Mexico
@REDGT04: your sensors could be fine. I had the same exact problem a month ago and what it turned out to be was that the front & rear tires were spinning at a different rate therefor throwing the speed sensors off because I had just purchased new rear tires with a little bit thicker sidewall. Even if the sidewall size is the same on the front and back on the tire, having wider tires on the back can cause the tire to bulge out making it thicker which was exactly what had happened to me.
Mustang_gt_03 is offline   Reply With Quote
Old 09-29-2011, 06:13 PM   #29
RedGT04's Avatar
What was it ?
---------- Post added at 06:13 PM ---------- Previous post was at 06:12 PM ----------
Hey is that ur actually car ?
Old 09-29-2011, 06:36 PM   #30
BlackGT's Avatar
Ya that's my car. I love it, never gonna sell it.
---------- Post added at 08:36 PM ---------- Previous post was at 08:33 PM ----------
What mustang GT 03 is saying is a good point. Now do you have after market wheels and tires or are they factory
Old 09-29-2011, 06:44 PM   #31
RedGT04's Avatar
That's a bad *** stang .... Right noel have factory wheels however I'm gonna replace the rear wheels I want something wider
Old 09-29-2011, 06:48 PM   #32
BlackGT's Avatar
I saw the pics and it looks like a clean car and a lot of potential. To really make it look nice really quick you should lower it with some H&R Springs give it a much nicer more aggressive stance. And definitely get the Mach 1 lip. The lip really makes the front flow with the rest of the car and it looks awesome. Highly recommended upgrades for not to much money. You can find both of these on www.americanmuscle.com. Awesome website I buy most my stuff from there.
---------- Post added at 08:48 PM ---------- Previous post was at 08:46 PM ----------
Ya those same wheels you have but instead black with a chrome lip look awesome on red mustangs. I know I had one. I Still got the rims.
Old 09-29-2011, 06:50 PM   #33
RedGT04's Avatar
Yeah I just can't dump that much money into it right off the bat u know but I deffly keep it in consideration for when I do have the money the inside of the car is on pristine shape it was a one owne garage kept
Old 09-29-2011, 07:04 PM   #34
BlackGT's Avatar
Ya definitely keep that in mind it will make a huge difference. Looks like you got a good buy there. How many miles?
Old 09-29-2011, 07:06 PM   #35
RedGT04's Avatar
Just over 40k and only paid 3800 lol the guy was an old guy and couldn't drive it anymore so he bought a town car
Removing cats from stock h pipe 2003-04 mach 1 Mach1Bob General Mustang Discussion 26 10-16-2014 07:38 AM
96 SVT Cobra appears Superchip is bad opinions on my options please Spiney SVT Mustang 15 11-07-2011 07:34 AM
cats and cars 04TRV6 General Car Discussion 14 09-19-2011 09:30 PM
h-pipe or x with cats 5.slow 1979-1995 Mustang GT 22 08-09-2011 11:37 AM
01:46 PM
